Álex Montoya
Will they cover the sensor area?
Why is 5K 16:9 only 4.8K?
Being an early RED One owner, I have a chance to get in early on the Epic,
but I am concerned that my inventory of lenses will not fully accommodate
the Epic sensor when shooting in the 5K mode. My Standard Speed Zeiss and
Angenieux zooms cover S35 with no problem, but I believe the image area for
the Epic can be just slightly larger. Would this cause some sort of
vignetting, or could I window down to my available coverage area? If so, how much
sensor real estate would I be wasting?
I've been getting some conflicting answers; so I thought I would put
it out on CML and REDuser to see if anyone has a verifiable answer. Please don't
respond unless you are sure, since it will only serve to further confuse the
matter.
With Sincere Thanks,
James Mathers
Cinematographer
Studio City, CA
Anyone has those numbers for the future Monstro 6K?
Of course no one can say for sure till we get our hands on an actual epic but this chart made by Steven Hilder is most likely accurate.
If we correlate this with the three widest Zeiss standard T2.1s that Matt Duclos has tested which all cover 30+mm then I'd say it's a good bet that Standards will cover. Just bear in mind we're pushing farther out to the corners so although they should cover you will still see a little port-holing on the wides.
This never actually bothered me as I think it gives the frame shape and helps guide the viewers eye in. Also stopping down a little seems to fix it easily.
So for comparison, a 4K 16:9 mode based on the hypothetical Monstro specs would have a sensor area of 24.576x13.824mm.
Hmm... 4.8K is really pushing it for a 4K finish.
Thanks Jeff!
How about a 6K 1.85 mode? (or 6K 16:9 mode)? Do you have the approximate numbers in mm?
You don't own a calculator? :laugh:
6um per pixel (square pixels), so 0.006mm x 0.006mm
FF sensor is 36mm x 24mm
36mm / 0.006mm = 6000 pixels across
6000 / 1.85 = 3243.24
36mm / 1.85 = 19.46mm
So I would expect 6K 1.85:1 to be 6000x3244 pixels and 36mm x 19.46mm. That is a diagonal of 40.92mm. Better plan on a 41mm image circle for full coverage of a 6K 1.85:1 format. The diagonal, for 6K 16:9 would be 41.3mm. So it really looks like if you want to shoot with the hypothetical Monstro 6K FF35 sensor, you will want glass designed to cover full frame if you want to shoot the full sensor width. Even shooting 6K 2.35:1 would need an image coverage circle of 39.13mm.
Yes, but you are assuming every pixel is active and there is no lookaround area planned.
Makes me wonder if there will be a "6K HD" mode that is 3x 1920 x 1080, i.e. 5760 x 3240.
*snip
