Hello redusers,
for a student short we got the task to develop an (mobile) AVID workflow on our on. Never worked with RED before, we started from scratch.
This is what we come up with:
Backup R3Ds on set on HDDs
=> transfer files onto the disks connected to our mobile AVID
=> transcode rushes in RedAlert with burn-ins in DHxHD.
=> Export an ALE from rushes => import that into AVID
=> connect DNxHD files in AVID
=> sync sound, sort an name everything, make a backup.
The editor will then take over the project an do the editing. Finally he exports an EDL for the finishing process (as I understood the offline files will then be replaced with the r3ds for precise colorcorrection).
As far as our testing goes, everything seems fine. Metadata shows up in AVID thanks to the ALE. :smile:
Not having a finishing software, we are not able to check if the last 50m of the marathon really work. We absolutly want to avoid that the finishing software doesn't "know" the connection between off- and online-files!
Any suggestions what we could have overseen? Anything what we must not do?
And: As we check the metadata in AVID, we see the path where the R3D was, when we rendered out the DNxHD.
Originally we wanted to copy the R3Ds of one day of shooting on the AVID-HDDs, so that we can develop the DNxHDs thenwithout the Source-HDDs having to be connected to the laptop all night.
When the rendering is successfully finished, we the would have erased the source-R3D-material from the avid-laptop (not from the source-HDDs of course!).
But knowing that the path of the R3D is know written into the ALE while exporting, and then erasing the R3Ds would bring us in real trouble, because the connection between off- an online would be lost.
Am I correct?
Why I'm asking this question? If we have to render the offlines from the original "place" (source-hdd) overnight any anything goes wrong, I cannot take the HDDs to the set next morning.
Secondly, I don't like the idea that the source HDD is running all night long...
Thank you for your replies!
Greetings,
Moritz
Am I correct?
Greetings,
Moritz
