Look's can't import.
Paul Harding
UK
In Redcine X 246 I saved a look to a 512MB SD card. After inserting the SD card into the Red One and go to import look it says there is none available
Any idea's
Try creating a look on camera first and saving it to the SD card. That helps create the folder structure to put your computer generated look into. If it's not in the right folder the camera won't see it. Plus the name needs to be 12 alphanumeric digits or less with no spaces.
Can't remember the folder name offhand otherwise I'd just say create that folder on the card first.
HTH!
Paul
HTH!
Paul
Thanks will give it go. I have sent the looks to Stuart.
Paul
Working OK It Does need the file structure from the camera.
Many thanks.
Paul
