Steven Sandt
- Sep 12, 2008
This morning I was getting a shot of the sky to use as a background plate for a special effects shot that I was compositing. I was shooting at 3K resolution and 24 fps. I was using a Sigma lens with a focal length of just under 40mm and I had it stopped down to f22. When I downloaded the shot, and started looking at it, I thought I saw a bug fly through the frame. Then when I examined it frame by frame, I couldn't believe it! I had a series of, I believe, eight frames in which you could definitely see a rod with the side lobes, and its characteristically weird path that they fly. The thing was apparently moving very fast, and I had the lens focused for infinity, so the images are not as good as some I've seen, but this was a real thrill anyway. Has anyone else out there gotten one of these using your Red One?
I finally was able to post the pictures, but it limits me to five pictures. Unfortunately unless you see the whole sequence, the flight path doesn't look too weird-but if you see the whole thing it really is strange-looking.
