Lenses that work for both 2/3 and S35?
Joel Arvidsson
46
Sweden
If I get an Scarlet 2/3 interchangeable now and later a S35. Wich red lenses can I use for both? Is it any equivalent to the fixed that you can get to the interchangeable Scarlet?
Shouldn't it be the other way around?
Smaller sensors with higher pixel density require higher quality lenses, better resolution and MTF, than larger sensors for best performance.
I don't think there will be much issue with good cine lenses like the RPP's or premium quality still lenses other than you need shorter focal lengths for wide angle coverage than is commonly available for 35mm.
Cheap 35mm still lenses will likely produce softer images on the 2/3" compared to good 16mm glass, the fixed Scarlet zoom, or the mini-primes.
