4.5k scope mode possible on 8 gb cards ?
Eric.T
Hi is the 4.5k scope recording modus possible with the 8 gb cf cards ?
and my second question would be.what is the highest data rate possible for the 8 gb cf card, is it still redcode 36 or is 42 also possible ?
sorry if this has been asked a lot but i couldnt find an answer
thanks in advance
eric
redcode 28 only, also I've had dropped frames on the non red lexar 300 cards,
but the red 8gb cards work fine.
wow ok. i thought rc 36 was possible.
would you suggest to use the red raid for handheld work ? or will i get dropped frames ?
do i get higher redcode with 4.5k on red drive ?
thanks for the knowledge you are sharing.
Yes, you can go to RC42 on the RED Drive at 4.5K. You shouldn't get dropped frames with the Drive doing handheld work. Unless you are throwing yourself into walls. :mad2:
Thanks for the info.
we will be shooting handheld from a willy jeep im not sure if the vibration will cause droped frames i think for that we will use the 8 or 16gb cards.
thanks for everything
eric
