Pasha Patriki
- Feb 14, 2009
- Toronto, Canada
- www.dop.ca
I am using Shotput Pro software and a 15" MacBook Pro for file transfer, Lexar FW800 Card reader, external drives are USB and/or Esata (through Expresscard 34/Esata adapter).
This system worked flawlessly for me, however now problems started happening, like some clips get corrupted, and some have green drop frames.
When I check the original CF card (16GB REdFlash), the footage is clean.
The surprising detail is that the drop frames appear in different places on two or three backup copies, so that puzzles me. Since Shotput Pro creates multiple copies simultaneously, so if there was an error, it would be identical on all copies?
The other surprise is that ShotPut Pro doesn"t actually detect, and shows "OK" message upon completing of the transfer. Only when I visually verify the files, I discover the corruption.
I tried changing card readers (I have 3 of them), cables, everything....
Can't figure out a pattern of why this is happening.
And why Shotput Pro byte verification does not detect the problem...
