Thread: 2x Extenders advice
Results 1 to 7 of 7
  1. #1 2x Extenders advice
    Maybe someone else has gone through testing extenders phase... to give some advice. I quickly tested and realized the cheap solutions off eBay don't step up to needed image quality.
    I am looking at Century Optics 35mm MKII, Schneider 2x, Optex any other under 2k? I realize that light loss is given and it's not same as having a lens, but... do any work as a 'passible' solution?
    Senior Member Gaston Fazio's Avatar
    Oct 2007
    Miami, FL
    Natalie:
    I would highly recommend the the I/BE 2x extender or the Duclos 2X extender.
    Century is fine also...
    Cheers!
    G
    HD HOUSE - www.TheHdHouse.com
    info@thehdhouse.com 305-597-7359
    RED DSMC2 Hellium, Gemini & Monstro - ALEXA LF - ALEXA MINI - VARICAM 35 - SONY VENICE
    COOKE S4 & S7 - Arri UltraPrimes - Zeiss SUPREME & CZ Zooms
    COOKE Anamorphics (SF) 25mm, 32, 40, 50, 65 MACRO, 75, 100, 135 & 180mm
    Angenieux Optimo 28-340mm - Angenieux Optimo 19.5-94mm
    Angenieux Optimo STYLE 16-40mm - Angenieux Optimo STYLE 30-76mm
    Canon Cabrio XK 20-120mm - CANON 30-300mm
    3-Wall CYC Studio, Sound & Lighting
    Senior Member Michael Lindsay's Avatar
    London UK
    We tested loads inc the IBE 2x and in the end went for the new TLS 2x (not the old one)... cheap and the best we used!
    Ps the optical design of the lens on the front really can throw things sideways... exit pupal position etc ...ideally the extender would be matched to one specific lens. What is your front taking lens?
    Senior Member Jacek Zakowicz's Avatar
    Jun 2008
    Most "cine" extenders out there are rehoused (for PL mount) still camera optics, Century and Optex are Nikon units AFAIK. IBE is most likely a ground up design and I'm not sure about TLS, not familiar with it. They are all good unless damaged. The two things to look for are the clearance that will affect the lens compatibility and making sure they are focused correctly so your zooms remain parfocal with the extender on. I don't think pupil size and location matter much since the 2x easily expands the S35 size image to FF so vignetting is unlikely to be an issue...
    Jacek Zakowicz, Optitek-dot-org, jacek2@optitek.org
    Professional Broadcast and Digital Cinema Equipment
    Nov 2009
    Available in PL and LPL to PL.
    Not 2x, but 1.6x...
    Works as both an extender or an expander (depends on your sensor format)
    Works with a variety of primes and zooms.
    Here is a home printable check gauge :
    https://drive.google.com/file/d/1wkP...ew?usp=sharing
    https://atlaslensco.com/products/atlas-16x-lf-extender
    London UK
    Hi Dan
    Thanks for info... any chance of seeeig a LPL to LPL 1.6 or 1.4x?
    Quote Originally Posted by Dan Kanes View Post
    Not 2x, but 1.6x...
    Quote Originally Posted by Jacek Zakowicz View Post
    Most "cine" extenders out there are rehoused (for PL mount) still camera optics, Century and Optex are Nikon units AFAIK. IBE is most likely a ground up design and I'm not sure about TLS, not familiar with it..
    What about the Optitek extenders, are they Nikon?
    (I have Optitek and TLS as my prime contenders.)
    Nils J. Nesse
    Epic-W Helium 8K in Bergen, Norway | Red Pro Primes | Tokina Cinema 16-28 & 50-135
Tags for this Thread
View Tag Cloud
