Thread: 2x Anamorphic 16:9 extraction aspect ratio
Results 1 to 4 of 4
  1. #1 2x Anamorphic 16:9 extraction aspect ratio
    Aug 2010
    Hullo,
    I think I read somewhere that there is a new 16:9 extraction from 2xANA mode for 16:9 delivery on the latest red firmware rather than 2:35:1 delivery like you can donon an Alexa but I can't find it in the menu anywhere. I know it will crop a bit but that's ok.
    Any ideas?
    Thanks!
    Craig Lees
    Reds, Alexa, Lomo Scopes
    UK
    Member Ryan Glover's Avatar
    Nov 2008
    Toronto
    Hey Craig,
    I believe its called "8:9"
    ryancglover.com
    RED ONE MX 0423
    LOMO standard speed 18,22,35,50,75
    LOMO squarefront anamorphic 35,50,80
    Aug 2010
    Wow I must really check out Reduser more often, sorry I missed this Ryan! Yes I figured it out, 8:9 works an absolute treat. Crops in a little but my 35mm Lomo SF is still pretty wide even on Helium.
    Keep safe.
    Craig Lees
    UK
    Something a bit cumbersome but cool to do for square ana is to roll camera 90 deg and then mount the lens so the ana element is still as should be. then the whole sensor can be in use to create a square ana image. Rolling shutter then goes sideways but yes you can get full monstro square ana images, cool for instagram if nothing else.
    Björn Benckert
    +46855524900 www.syndicate.se/axis
    Monstro & Komodo
