REDUSER.net
Go Back   REDUSER.net > RED One Camera > RED Workflow > Apple Workflow
Reply
Thread Tools Display Modes
Old 05-27-2010, 03:48 PM   #1
Phil Bates
Phil Bates's Avatar
Default Jim, More Reasons Why 1080p is Not Enough
Jim, so sorry I didn’t get to post in your Recon thread, but I wanted you to know 10 reasons why 1080p is not enough for me.
1. I want to be able to re-frame the compositon (crop) without loosing resolution.
2. I want the option to introduce pan, tilt, rotation and/or zoom.
3. I want the extra margin to be able to stabelize without duplicating edge pixels, stretching the edges, or using any other image compromizing trickery.
4. I want the extra margin to be able to correct for non-level support, bad pans, tilts, or zooms.
5. I want the extra margin to be able to correct for barrel distortion or other lens anomalies.
6. I want the extra resolution so when I size down to 1080p I get the pixel interpolation benefit of natural sharpness, less noise and less compression artifacts.
7. I want the option to layer(or dissolve) two overlapping images where the elements may not match exactly.
8. I am tired of depending on DSLRs for high resolution timelapse with all their limitations and the flicker they can introduce. (I’ve mostly resolved the flicker thing, but still...)
9. I offer footage for all kinds of uses that go way beyond broadcast, including digital signage, concert backdrops, projects for 4K projection, gaming and much more.
10. My customers are asking for ultra high resolution images for testing purposes.
With 4K I can do several of these items at once without compromising image quality, like doing both an artificial pan and image stabilization.
These are items I deal with daily. They are practical and affect my business and customers NOW. 1080p is DEFINITELY not enough.
Phil
__________________
Artbeats: http://www.artbeats.com
Phil's fine art site: http://www.prbates.com
"Soli Deo Gloria"
Phil Bates is online now   Reply With Quote
Old 05-27-2010, 04:30 PM   #2
Chris Pickle
Default
Quote:
Originally Posted by Phil Bates View Post
1. I want to be able to re-frame the compositon (crop) without loosing resolution....
I still trying to figure out how this is done. Apparently, it's bloody difficult. I have stuff reframed in FCP, but for the life of me, or anyone else it seems, I don't know how to go back to the 4k and re-render those shots to get a crop that matches the FCP shot.
very very frustrating.
__________________
Chris Pickle
http://www.savinggracethefilm.com/
Chris Pickle is offline   Reply With Quote
Old 05-27-2010, 04:39 PM   #3
Phil Bates
Phil Bates's Avatar
Default
I live in the After Effects world and it's fairly easy to do there. I realize that's small comfort to you. I wonder if it's more of a compositing task than an editing one. Maybe someone else will chime in.
Phil
__________________
"Soli Deo Gloria"
Old 05-27-2010, 05:18 PM   #4
Chris Pickle
Default
Phil
How do you do it in AE? How does AE do the debayer etc? Or do you do the debayer at 4k and crop in AE?
__________________
Chris Pickle
Old 05-27-2010, 10:40 PM   #5
Phil Bates
Phil Bates's Avatar
Default
Quote:
Chris, you can literally create any frame size in AE that you want. For example, I might set a 3K 16:9 frame size. I import a 4K 16:9 .R3D file and it automatically crops, only showing the 3K window. I can then scale the 4K image down (or even up if I want) and re-position to show as much or as little of the 4K image that suites me. If the 4K image has a tilted horizon, I can fix it with a rotation, then re-size slightly larger than the 3K window to show the clean edges. I hope this makes sense, it's like ultimate control, with all the variables (scale, position, rotation etc.) key-frameable so they can change over time.
Regarding the de-bayer, it's actually pixel interpolation, similar to what happens when re-sizing an image in Photoshop. AE calculates all pixel scale, rotations, and positions to the thousandth of a pixel in 16 bit color space.
Phil
__________________
"Soli Deo Gloria"
Old 05-28-2010, 12:16 AM   #6
Alexis Hanawalt
Alexis Hanawalt's Avatar
Send a message via AIM to Alexis Hanawalt
Default
I did this for the entirety of a Comedy Central special airing next month - we pushed in on every shot in the show. I re-transcoded everything out of RedAlert at 4K Prores444 and swapped out the media in the sequence with the full size versions (which as you probably know, you can see in FCP, but not play back in real time.) Then, the hard part - I went through the whole show, shot by shot, and looked at the magnification and xy values of the 1080p version I originally cut and manually multiplied that (I forget what I had to multiply by) to arrive at the proper magnification value for the 4K version. All along I presumed there could be a faster way to automate this for the whole sequence by exporting to XML and modifying the sequence parameters in Excel, but it only took me half a day to just do it manually.
Alexis Hanawalt is offline   Reply With Quote
Old 05-28-2010, 05:50 AM   #7
Jim Retar
Default
Most of your points seem to suggest that you are finishing in 1080p ... so what you are saying is that 1080p acquisition is not good enough.
I think what Jim was alluding to was that a 1080p finish is not good enough.
__________________
StockFuel - Stock Audio for film and TV.
Jim Retar is online now   Reply With Quote
Old 05-28-2010, 06:16 AM   #8
Michael Olsen
Default
Though it does speak volumes that, even while 1080p delivery remains a popular standard, 4K+ acquisition offers numerous benefits unavailable to 1080p or 2K aquisition. While resolution isn't everything, it can certainly help one do a lot.
Michael Olsen is offline   Reply With Quote
Old 05-28-2010, 06:23 AM   #9
Terry Wester
Terry Wester's Avatar
Default
Phil
I could not agree with Phil more. Right now for us there is no interest in finishing in 4K, but being able to zoom in to the frame 190% is the ultimate "Fix it in Post" tool. Once clients really get that you can do this it changes how they shoot things. We are using Assimilate Scratch, and it makes the process a turn of a knob.
__________________
Terry Wester
Dallas, TX
Post-Production with Scratch DI/Transcoding
www.12forward.com
Terry Wester is offline   Reply With Quote
Old 05-28-2010, 08:23 AM   #10
Phil Bates
Phil Bates's Avatar
Default
Now that I have started working in 3K and 4K, I can't imagine processing footage without it. We are currently seeing some demand for 4K footage, however it is early yet. For us, 4K is mostly about future proofing and producing better 1080p.
Phil
__________________
"Soli Deo Gloria"
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
All Content Copyright Landmine Media, Inc. 2010
