REDUSER.net
Go Back   REDUSER.net > Red Digital Cinema > Recon
Closed Thread
Thread Tools Display Modes
Old 11-30-2009, 04:17 PM   #11
Jarred Land
Fire Chief
Jarred Land's Avatar
Default
BOMB EVF ( PHOTO )
The Bomb EVFs are now out in the wild being tested by some of our beta testers. Production has begun on the mechanicals and the optics. One great new feature that just snuck in in time for production is the Bomb EVF now has an internal heater, to allow for extremely cold operation. BOMB EVFs will work with all RED CAMERAS, including the RED ONE. Shipping is slated to begin end of January.
Jarred Land is offline
Old 11-30-2009, 04:25 PM   #12
Jarred Land
Fire Chief
Default
RED STATION ( Photo )
RED STATION has also entered pre-production. Each "Module" can work with the base station in a stack of 1 to 4 units, or independently via Firewire 800, 400, ESATA or USB 2.0.
Old 11-30-2009, 04:32 PM   #13
Jarred Land
Fire Chief
Default
Scarlet 8x Fixed ( Photo )
Old 11-30-2009, 04:34 PM   #14
Jarred Land
Fire Chief
Default
Scarlet 8x and Scarlet 2/3 removable ( Photo )
Old 11-30-2009, 04:36 PM   #15
Jarred Land
Fire Chief
Default
25mm Mini Prime ( Photo )
Old 11-30-2009, 04:37 PM   #16
Jarred Land
Fire Chief
Default
We also have something new...
Old 11-30-2009, 04:39 PM   #17
Jarred Land
Fire Chief
Default
REDMOTE PRO.
Old 11-30-2009, 04:42 PM   #18
Jarred Land
Fire Chief
Default
REDCINE - X
There will be a new version of REDCINE-X released this Wednesday with a ton of updates.
Here is just the short list:
Video Player - Anamorphic Aspect fix
Video Player - Fit width/height/both options
Video Player/Audio Player - Preroll added
Video Player - Next Frame and Previous frame keys fixed
Video Player - caching improvements
Video Player - opengl improvements
Rocket: 4.5K scaled output to a 4k monitor
Rocket: Rocket Breakout Box support
Rocket: dual-link SMPTE352 ANC bit handling fixed on Rocket HD-SDI out
Rocket: frame color problems on old macpro workarounds implemented
Export - DPX Software mode added
Export - DPX Rocket output
Export - DPX snapshot added
Export - Quicktime output bug fixed
Export - Upscale 2048x1024 to 1920x1080 support (for Rocket modes)
Export - Burn in now works for Stretch XY
Export - Avid export restructuring
Export - Ale is now automatically exported when choosing an avid export.
Export - Croping/Fitting via Framing Settings
Export - Crop Height 0.9 fix
Export - Software Zoom/Crop fixes added.
Export - Detailed logging added to export start.
Win32 - Rocket Detection on start fix
Win32 - File menu /Exit option fixes
Gui - Escape and return shortcuts added to Select Exporter dialog
Gui - Spacer slug drawing while dragged fixed
Gui - Select Exporter Dialog - Positioning of header fixed
Gui - Select Exporter Dialog - Ok/Cancel buttons sizes fixed
Gui - Select Exporter Dialog - Incorrect resolution being selected while editing a preset fixed.
Gui - Select Exporter Dialog - Burn in color boxes now show colors properly on load/edit
Gui - Select Exporter Dialog - Burn in Lower right combo box fixed.
Gui - Select Exporter Dialog - Output to selected folder options re-enabled
Gui - Select Exporter Dialog - Misc Text alignment and theme fixes
Gui - Select Exporter Dialog - Background fixed
Gui - Select Exporter Dialog - disabled non-functioning fit/resample options in the dialog. - use framing tool for fitting clips
Gui - Modal fix for dialogs
Gui - Slugs now only update on release while being edited from the right.
Gui - Ext Audio Channel items hidden
Gui - Project saving/loading
Gui - Added Clip Framing tool
Gui - Added Clip Framing Presets
Gui - Removed white background on export tool corner
Gui - Saves and restores all window positions on start and exit.
Gui - Apply to bin, selected in bin, timeline, selected in timeline added to various tools as appropriate.
Gui - Saves selected presets and apply to options between sessions.
Gui - Remembers the last directory used for save/open dialogs
Gui - Bin - Delete clip from bin added to right click context menu.
Gui - Bin - Metadata viewer added to right click contact menu.
Gui - + - and "apply" controls normalized across tool windows.
Gui - Bin and filebrowser zoom settings are now remembered between sessions.
Gui - Active bin tab is remembered between sessions.
Mike Seymour from fxguide.com & fxphd.com has put together a great little video on showing the RED Rocket™™ in action in REDCINE-X and ROCKETCine-X that is worth watching.
Old 11-30-2009, 05:29 PM   #19
Jarred Land
Fire Chief
Default
Scarlet 8X and Nikon D3 ( for scale )
Old 12-01-2009, 08:08 AM   #20
Jarred Land
Fire Chief
Default
UI
Closed Thread
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
All Content Copyright Landmine Media, Inc. 2010
