REDUSER.net
Go Back   REDUSER.net > RED One Camera > RED ONE - General
Reply
Thread Tools Display Modes
Old 03-16-2009, 07:07 PM   #1
Mark Andersen
Registered User
Mark Andersen's Avatar
Default Drop Frames at Rock Concert?
I recently shot a live rock show and had a terrible problem with dropped frames. I can only guess this may have been caused by low end vibrations from the music or some other type of harmonic resonance causing the drives to vibrate and skip. Has anyone had a similar Problem? Are there any experts on this phenomenon?
Mark Andersen is offline   Reply With Quote
Old 03-16-2009, 07:19 PM   #2
HD Hildebrand
Registered User
Default
Yes, never seat your camera on a speaker. Also, if you're near the speaker the base may do that. I've only had it when going up to the stage and putting it on the speaker while framing up. I avoided ever since and have not had problems.
HD Hildebrand is offline   Reply With Quote
Old 03-16-2009, 07:36 PM   #3
Brent J. Craig
Registered User
Brent J. Craig's Avatar
Send a message via AIM to Brent J. Craig Send a message via Skype™ to Brent J. Craig
Default
There are reports of this all over Reduser. You have a delicate platter spinning at 7200RPM with a piece of ceramic floating only microns above it. What do you think happens when you shake it violently?
Loud music, gunshots, helicopters, fast cars and screaming are all incompatible with delicate spinning hard drives.
__________________
Brent J. Craig . com
Brent J. Craig is online now   Reply With Quote
Old 03-16-2009, 07:48 PM   #4
Sam Winzar
Registered User
Default
I had it happen really bad when filming an electronic act. It was funny (in that non funny way) watching the drop frame counter go up with every bass beat.
Get as far away from the subs as you can and maybe try wrapping the drive in something to sound proof it.
Sam Winzar is online now   Reply With Quote
Old 03-16-2009, 07:54 PM   #5
Steve Sherrick
Registered User
Steve Sherrick's Avatar
Default
Buy one of the 3rd party shock mounts and if that is not enough to keep frames from dropping, opt for the REDRAM drive.
__________________
Steve Sherrick
Chief Collaborator
Obscure Knowledge Productions
Check out the RED Filmmaker Blog
Local 600 DIT/Operator
Steve Sherrick is offline   Reply With Quote
Old 03-16-2009, 08:02 PM   #6
NateWeaver
Registered User
NateWeaver's Avatar
Default
Quote:
In my experience, the ET shock mount won't do it. It's the waves penetrating the HD case, from what I can tell.
Luckily, any sort of cloth wrapped around the drive maybe an inch or two thick has always solved it for me...you'd think you'd want a lot more to insulate but it's never taken much to fix for me.
__________________
Nate Weaver
Director/D.P., Los Angeles
www.nateweaver.net
NateWeaver is offline   Reply With Quote
Old 03-16-2009, 08:11 PM   #7
Steve Sherrick
Registered User
Default
Yeah, I suppose it's a crapshoot. I filmed a techno show with zero dropped frames using the ET mount. Wonder if it has anything to do with where the drive is attached. I always hang mine off the side of the camera vertical.
If I was in a pinch, I would definitely use the cloth. Best solution though is REDRAM.
__________________
Steve Sherrick
Chief Collaborator
Old 03-16-2009, 08:17 PM   #8
Jonathan Stevenson
Registered User
Jonathan Stevenson's Avatar
Default
Where's Mitch Gross? How about a RedSock! :watsup:
Jonathan Stevenson is offline   Reply With Quote
Old 03-16-2009, 08:35 PM   #9
NateWeaver
Registered User
NateWeaver's Avatar
Default
Quote:
I've wondered if a neoprene sleeve would do it.
__________________
Nate Weaver
www.nateweaver.net
Old 03-16-2009, 08:38 PM   #10
NateWeaver
Registered User
NateWeaver's Avatar
Default
Based on the audio engineering classes I took 15 years ago, it probably has more to do with where standing waves are in the room, the specific amplitude, and specific frequency.
In other words, very hard to predict other than really loud equals danger, and in my cases, spare clean tshirt over drive=fixed.
__________________
Nate Weaver
www.nateweaver.net
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
All Content Copyright Landmine Media, Inc. 2009
