Thread: Epic 2K 300FPS record time for 256 GB card
Results 1 to 4 of 4
  1. #1 Epic 2K 300FPS record time for 256 GB card
    Aug 2008
    Calgary | Vancouver
    Evening Gents and ladies
    Anyone care to enlighten me where I can figure out how long I can shoot 300FPS in 2K highest compression setting.
    I tired extrapolating this
    http://www.reduser.net/forum/showthr...6GB-HDRx%99%99
    But it gave me a strange answer.
    Basic math would be
    276 minutes at 5K 2-1 5:1 at 24 fps
    (24x300)/276=26 minutes of real time recording.
    Is this right???
    Best Regards
    Aaron Bernakevitch
    www.4kfilmproduction.com
    Show Reel http://vimeo.com/9036753
    http://www.imdb.com/name/nm2331563/
    RED # 4455 "DUCHESS"
    - Things usually work out better than you plan. When you`re shooting a film you`re so close to it, it rarely lives up to your expectations while you`re there. You always want it to be better, more perfect. When you see a cut, maybe two or three months later, you come to it fresh. It`s generally much better than you thought it would be" RD
    Jan 2012
    Newport Beach, CA
    If you have an iPhone download KataData it's a great Red data calculator app. This is what I get: 17.1 minutes. That's at 7:1 compression which I believe is the maximum at 2K @ 300 frames per second.
    Aug 2009
    Lakewood CA
    128GB SSD, 2K WS @ 24FPS @ 8:1RC = ~300min
    So based off that, 300FPS being 12.5x that of 24FPS....
    128GB SSD, 2K WS @ 300FPS @ 8:1RC = ~24min
    So you should get under 24min I believe.
    On a test with a 64GB and 128GB card, black frame, 300FPS 2K WS, 7:1, recording ~1 minute gave me a R3D of 6.7GB, so on a 128GB card I would get roughly ~19minutes total.
    Of course this is a Black Frame being recorded , in comparison a test with motion and detail, 1minute gave me roughly 6.9GB.
    Hope this helps a little bit
    Feb 2008
    UK
    a frame is a frame ...
    I think the calculation in the sticky about record times shows 0.66Gb per min at 7:1 compression 2K and 24fps. that works out at 1440 frames = 0.66Gb
    300 frames = 0.1375 Gb - that's 1 sec.
    1 minute of that = 8.25Gb
    so a 256 card should give you about 30 - 31 mins (all relative of course) at 7:1 in 2K
    of course I could be missing something :-)
