Thread: How to blimp a 6500W Honda generator?
Page 1 of 4 1234 LastLast
Results 1 to 10 of 32
  1. #1 How to blimp a 6500W Honda generator?
    I am planning a shoot next month in a forest and I'd like to use a 6500W Honda generator. I have 100 meter (328 feet) of cable at my disposal. The generator is rather noisy so I want to blimp it. Has anyone done this or has any idea how to do this?
    Willy Faes
    Jan 2009
    Toronto Canada
    Not 100% effective, but building an earth wall around it cuts the direction of the sound. if you do three walls with the open away from your shoot direction, then put something like foam or a small mattress or something over it may help a lot.
    Director|DP
    Octocopter Rental - Toronto
    EPIC|2125 - SCARLET|3568
    www.serengetifilms.com African Stock www.4kafrica.com
    I've built a 3 walls and a roof plywood and foam pad enclosure for the 6500's - It's not that effective, but if it's over a hill and downwind you might get away with it. It's being acceptable mostly depends on how much other background noise there is present. One shoot years ago in Mendocino we were able to rent a solar panel, battery, inverter array that worked pretty well and of course was completely silent.
    Matt Uhry
    www.mattuhry.com
    Matt, there is almost no other background noise but I'll do some tests with a 3 wall + roof construction.
    Willy Faes
    Senior Member Nick Gardner's Avatar
    Oct 2007
    Baltimore
    Being in the woods makes it harder, But a friend of mine did this in a village in Afghanistan with a construction generator -
    Rent a bobcat, dig a trench, put the genny in the trench. Cover the top of the trench with 4x4s and a sheet of plywood, put the dirt from the trench on top of the plywood. But really, at this point, just rent a blimped genny ;-)
    Nick
    Sep 2009
    come out of the 220/240 30 amp plug of the genny , then do a run of that style cable , then a 480240to240/120 step down transformer.. then exit the transformer with 120 bates , you can get hundreds of yards on retail fairly cheap , that should get you very far , generators, do not like ambient heat around them , put a fan on it , if its going to be buried or blimped , and mess around with lag mics, or get a boom op with a 816 that has a super narrow precise pattern , but a novice with a 816 is a whole different problem .
    Quote Originally Posted by Peter Berger View Post
    A little more information would be helpful. What model 6500W Honda generator do you have access to? What is the gauge of the 100m of cable? Is that 100m per light or does that have to be split up between lights? In other words, how far away can the generator be? What lights are you using?
    Peter Berger
    Peter
    The generator is a EU65is (European model). The lights we are a 4kW and a 1.2kW. We can use to cables, one for the 4kW and a another for the 1.2 kW. I don't know what the gauge is of the 100m cable is.
    Willy Faes
    Sep 2009
    weird, i just took 10 minutes, explaining the problems you might encounter , aside from sound, as in 4k and 1.2 k hmis , on one circuit in that genny.
    your neutral leg being undersized for the return leg of that proposed circuit . like reducing a firehouse to a garden hose " back pressure " .. so you may have flicker , even if it doesn't pop the breaker from being over-amped.
    i would look into renting a 2000 watt inverter also , to run the 1.2 k while the eu6500is runs the 4k , that genny will screeeeeeam while trying to put out 6k for hours
    thus , the step-down , thats what i do with mine and why
    good luck , it can be done , just not a easy task
    While Chad’s approach would work with one of the enhanced 7500W EU6500is (US model), it won’t work with the EU65is (European Model.)
    Here’s why. The US model can be modified to generate 7500W at 240V. The company that modifies the generators also builds a custom 240-to-120V step-down transformer/distro that converts the enhanced 240V output to a single 60A/120V circuit (they also now build a transformer/distro that provides a 84A/120V circuit from Hondas new 10kw EB10000 generator.) The transformer/distro has a 60A Bates receptacle so that you can use standard film distro to plug both the 4k and 1.2 HMI into the transformer/distro. If the 4k has a Power Factor Corrected (PFC ) electronic ballast that will draw 38A and the 1.2 also has a PFC ballast that will draw 11.5A, the combined load of 49.5A is well within the capacity of the 60A/120V circuit provided. As an added benefit, these transformer/distros have selectable voltage boost taps that enable you to compensate for voltage drop over a long cable run and the voltage drop you will have on the generator when you fully load it. This feature enables you to operate the generator at a distance where you won’t hear it, yet maintain full line level on set to your lights so that they don’t cut out from low voltage (a chronic problem using HMIs on portable Honda generators.) So, Chad’s suggestion is a good one if you had access to a US model EU6500is.
    Chad’s suggestion won’t work with the European model EU65 because that model is configured with three 16A/240V receptacles. A step-down transformer/distro plugged into one of these receptacles will only provide a 32A/120V circuit, which is not large enough to power the 4k which draws minimally 38A at 120V with a PFC electronic ballast. Even though most electronic ballasts are multi-volt ballasts, and will operate at 240V, you won’t be able to operate it safely at 240V off the generator because its’ 240V load of 19A will overload the 16A/240V circuit on the EU65is. The new 10kw Honda EB10000 has a 50A/240V twist-lock receptacle from which you can pull a max of 41.6A at 240V (enough to run even a 6kw HMI), but unfortunately that model is not available outside the US.
    I would suggest swapping the 4k HMI for the new 1800W Arri M18 with Arrimax reflector. The M18 will give you output comparable to that of a 4kw Fresnel, but only draw about 10A at 240V, so you will be able to plug it into the 16A receptacle of the European model EU65is. The EU6500is (both US and European models) are quiet enough that you should have no difficulty getting clean audio with proper miking if you run the generator out of your grip truck or van 100m away.
    Good Luck
    Peter Berger
    Peter, thank you for your explanation but we already us our 4kW + 1.2 kW with success with the 65EU generator. I think there is one 20A receptacle. My main concern is how to make the generator less noisy.
    Willy Faes
    what does blimping a generator mean?
Tags for this Thread
View Tag Cloud
