Thread: Head Worn POV Shoot - Existing Rigs and Camera Choice.
Results 1 to 7 of 7
  1. #1 Head Worn POV Shoot - Existing Rigs and Camera Choice.
    Hi Guy's Events have conspired to keep me from attending Cinegear and NAB the last 2 years and I was wondering if anybody had and thoughts on what was the best head worn camera rig ? Smaller sensor ( like 2/3" ) would help in this case. Not especially budget sensitive, and looking for better quality and much more control than something like a go-pro or a contour. HDSDI output would be helpful too.
    Has anyone use the SI-2k Nano ? What are some of the better cube cameras out there ? Any opinions on sweet C-Mount lensing ?
    Thanks,
    Matt Uhry
    Dec 2009
    Chatsworthless, CA
    I would advise against going this far:
    www.cinesound.tv | location sound / post-production consultant
    Senior Member George Tsai's Avatar
    Nov 2009
    SoCal
    Quote Originally Posted by Marc Wielage View Post
    Lol, I want to see someone head mount an Epic:-P
    George Tsai :-D
    www.gtsai.com
    EPIC-X 444
    Full Camera Package, and DIT services available
    "Sanity is for the weak!" - Dawn of War
    I do not suffer from schizophrenia, I quite enjoy it.
    And so do I
    Nov 2009
    Vancouver Canada
    Junior Member
    Nov 2011
    I created a helmet-cam rig a few weeks ago using a motorcycle helmet and several clamp arms/weights. Here is a photo of it
    I used a T2i for the camera, because of its high quality sensor (same as 7D) whilst still maintaining low weight and the Tokina 11-16mm ultra-wide as my glass. The ultra provides a slightly distorted field of view at 11mm which I think works great at replicated the field of view of the human eyes. On top of that I had a teradek cube to wirelessly monitor the camera from an iPad - the whole thing worked out great and I would highly recommend something similar.
    Senior Member Eric Haase's Avatar
    Mar 2009
    Quote Originally Posted by Matt Uhry View Post
    Thanks,
    Matt Uhry
    Matt,
    I just did a helmet mount shoot with the Si2k. It was not the smallest nano that uses c-mount lenses but the one i think that is called the si2k mini. It takes PL lenses. We used mostly a 9.5 and 12mm optar (illumina) because we were matching another part of the shoot done in the UK. I had no choice in camera or lenses but it was a fun experience to play with the rig. In L.A., Radiant Images have the whole setup and Nick over there is really knowledgable and helpful. My main caveat is that the REC709 viewing LUT is pretty hideous. The camera still has pretty clippy highlights- probably a bit better than the GoPro in terms of DR (although GoPro with technicolor cinestyle loaded in I don't know how it would compare). I think a better image still than GoPro and a more robust system with more controllable options. Recording on the Cinedeck Extreme in Cineform Uncompressed RAW was pretty easy. PM me if you want more info.
    Eric
    Eric
    cinematographer
    www.ericjhaase.com
    Dec 2008
    Los Angeles, CA
    Quote Originally Posted by George Tsai View Post
    LA-based DP http://davidcarstens.com
    Fujinon Cabrio 19-90 // Zeiss CP.2 Primes EF+PL
