Thread: Is RCX crushing my blacks?
Results 1 to 3 of 3
  1. #1 Is RCX crushing my blacks?
    Senior Member Von Thomas's Avatar
    Jun 2008
    I've been using RCX for a long time now, but I've noticed in the past day, my files, when viewed in QT, are dark and crushed. Can anyone give me a reason, and a solution?
    Von
    Von Thomas
    IATSE Local 600 DIT
    International Colorist Academy
    www.icolorist.com
    www.digitaltechnyc.com
    www.vonthomas.com
    http://reddigitalmotionandstill.blogspot.com/
    RED #5721
    Senior Member Cory Petkovsek's Avatar
    Sep 2010
    San Diego
    What codec are you exporting with? QT supports like 20. QT also has gamma issues which you may be running into. What happens if you play the file through VLC? Do you have a 10-bit display? Perhaps RCX shows you 10-bit, then you export to 8-bit. What if you export to a non-qt codec?
    Cory Petkovsek
    Corporate Video
    Do you have the SPMTE setting checked in the export options?
