Thread: Split image on playback
Results 1 to 6 of 6
  1. #1 Split image on playback
    Senior Member Jeff Barklage's Avatar
    Nov 2007
    Cincinnati, OH
    I'm on Build 3.2.13
    using a Pix 240 or AJA KI miniPro for ProRes conversions (depended upon which was available which day)...
    We just shot a job entirely at 100 fps (project rate 23.97) thus I had to acquire the ProRes files via camera playback.
    This was a beauty shoot with lots of lens flares and bright sparkley stuff...and when playing back from the Epic, the image would tear/split.
    Crazy!
    i tried to restart playback on those particular clips...same thing.
    It got to the point that playing back was simply impossible and we are having to pay the post house to do these conversions out of our own pockets.
    So...what gives?
    Is it this particular build?
    I've heard so many horror stories about newer builds that I am afraid to experiment on them whilst being on the clock and being paid to have a working camera system.
    Any remedies? Or do i have to shoot everything with flat/bland lighting?
    cheers,
    Jeff Barklage, s.o.c.
    www.barklage.com
    agent: TDN ARTISTS www.tdnartists.com
    online reel: http://www.interdubs.com/r/tdnartist..._Jeff_Barklage
    Vimeo Reel:*http://www.vimeo.com/user5504817
    USA based DP
    Senior Member Russ Fill's Avatar
    Oct 2007
    World wide working
    I know this is probably not what you want to hear right now Jeff but,,,Im kind of the same thinking as I have had to learn the hard way to only use non beta versions for the real deal. And maybe even waiting for the build to be out there for a while to make sure there is not any problems when it is used in mass...
    I load the beta versions on shoots that I can go back and have a mulligan but never on the, this is the only time we can get this shoots anymore.
    Senior Member Eric Haase's Avatar
    Mar 2009
    I've never seen that before. Sounds like you should contact RED and send in your log file. I would advise to stick to the release versions for professional work. Betas are betas for a reason and there is rarely a feature on the beta that you HAVE to have for your shoot at this point in the evolution of the Epic.
    Eric
    cinematographer
    www.ericjhaase.com
    Nov 2007
    Cincinnati, OH
    Thanks guys....I load in the latest release firmware.
    cheers,
    www.barklage.com
    USA based DP
    Jan 2010
    Playback is great when it works, but 30-40% of the time is doesn't work flawlessly and you get things like this. There is room for improvement and more stability of the playback mode...Ive had enough moments with clients waiting for playback and the camera failing and i have to switch a few times between playback and live mode before it works, please red get this fixed!
    if its tearing apart / split on the hdsdi out - ive seen that on various build not only beta. It usually occurs after you magnify.
    try the Different 50/60 hertz - try turning off the hdmi - try the different out put settings "clean.. etc"
    Sidney Lexy Plaut
    filmmaker.
    Epic Package. Complete set of rehoused Cooke s2&3 series 2000... and lots of toys.
    www.vimeopro.com/sidneydp/sidneydp
