Thread: back focus problem? with 16mm lens Zeiss MII
Results 1 to 5 of 5
  1. #1 back focus problem? with 16mm lens Zeiss MII
    Senior Member Stefano Ceccon's Avatar
    Oct 2011
    Italy
    hi,
    I bought a Zeiss 8mm MII PL for 16mm.
    Wide for 2k 120 frames R1MX
    I have a Allstar-mount, and some lens, zoom and prime.
    The lens Zeiss 8mm does not focus to infinity, all other yes.
    back focus problem? but only for one lens??
    thanks for any help
    Oct 2011
    Italy
    I measured:
    to infinity, focuses to 1.45 meters!!
    Senior Member Jacek Zakowicz's Avatar
    Jun 2008
    remove about 0.07-0.1mm shim from under the mount and it should get you pretty close.
    Jacek Zakowicz, Optitek-dot-org, jacek2@optitek.org
    Professional Broadcast and Digital Cinema Equipment
    Oct 2011
    Italy
    thanks,
    behind the lens?
    an operation of precision
    you do it?
    what it costs?
    Jun 2008
    the shim should be under the stainless PL mount.
    Just take out the screws and lift it.
    you need a precise measuring tool to check the (shim) thickness- preferably a micrometer.
