Thread: DaVinci Resolve v9 Released
Page 2 of 7 FirstFirst 123456 ... LastLast
Results 11 to 20 of 70
  1. #11
    Senior Member jake blackstone's Avatar
    Nov 2007
    Can someone with Elements panel verify, that the fourth trackball on Elements panel works correctly in Log mode? If it is, it may be the perfect reason, at least for me, to move over to Elements. I just hate to spend $3500 just to be able to use the Log grading, where a simple panel re-mapping would do...
    Is it for CUDA cards only?
    Epic-X #2165
    www.4kstudio.sk
    Senior Member eric a wahl's Avatar
    Oct 2008
    Los Angeles, CA
    good stufff....
    Thanks,
    Eric A. Wahl - cinematographer / colorist
    ericwahl@usa.net
    www.imdb.com/name/nm3469445
    RED EPIC-X SN#02061
    Located at The Brewery Art Colony in Los Angeles, California
    http://en.wikipedia.org/wiki/The_Brewery_Art_Colony
    Senior Member Fred Beahm's Avatar
    Sep 2011
    Seattle, WA
    Woot! Can't wait to get home and download. Anyone know when the full release drops?
    Editor / DIT
    MPEG - IATSE 700
    Spliced Films - Seattle, WA
    IMDb: http://www.imdb.com/name/nm2652243/
    Can someone with Elements panel verify, that the fourth trackball on Elements panel works correctly in Log mode? If it is, it may be the perfect reason, at least for me, to move over to Elements. I just hate to spend kr21,235.28 ($3500) just to be able to use the Log grading, where a simple panel re-mapping would do...
    Yes! Could someone please verify this?
    Quote Originally Posted by Christian Berg-Nielsen View Post
    I'm quite sure it does not. None of the other mappings seem to have changed from the set available in 8.2.
    I'm willing and anxious to be proven wrong, though.
    Senior Member Peter Moretti's Avatar
    Apr 2008
    Are there any changes to HDRX support? In 8, it seems that to use HDRX you add the HDRX track as a second source and also add a layer mixer node to blend the normal and HDRX tracks. Perhaps that is good enough, I'm not sure.
    Thanks all.
    1110001100010102
    Nov 2007
    Quote Originally Posted by M Most View Post
    I'm puzzled, as I can't imagine, that the company would release a major feature, that is only usable to, what, may be .1% of users, that are in possession of BM panel.
    I'm not complaining, because at this price BM can pretty much do anything they like. I'm just puzzled...
    Senior Member mikeburton's Avatar
    Sep 2007
    Sacramento CA
    Quote Originally Posted by jake blackstone View Post
    I can verify that "Shadow", "Midtones" and "Highlights" are all mapped and work on the element panel just fine but "Offset" does not map to the fourth trackball yet. As of now the fourth trackball is useless in Resolve. But, I've been on the Beta for over a month and updates come pretty fast, and none of the LOG controls were working at all up until yesterdays build before release so give it time, i'm sure it will happen soon. Also, it would be nice to have the "Contrast" and "Low Range" "High Range" mappable to one of the "Primary Knobs" since there are so many empty knobs not doing anything currently. I think once the Element has most of the functions mapped properly to it you will feel like its a really worthy upgrade. Even without the functionality i wish it had mentioned above I'm still using it day in and day out and love it.
    Member Benjamin Hopkins's Avatar
    May 2009
    Los Angeles, CA
    Let's give it a try. I always believed that some version of the 9.0 would get released in July, even if on the 31st. Thanks BMD.
    Ben Hopkins
    Hueman Interest
    Digital Cinema Workflow
    Pre-Post + Post Supervisor
    310-765-4051 [tel]
    310-765-4052 [fax]
    ben@huemaninterest.com
    www.huemaninterest.com
    twitter.com/huemaninterest
    Digital Cinema Post On-Set | Acquisition | Secure Backup | LTO Archive | Flanders Scientific monitoring | Rocket Dailies | Complete Data Workflow Architecting
