Thread: Batteries for DIT cart
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. #11
    Senior Member Steve Sherrick's Avatar
    Boston
    Xantrex is an option but keep in mind that your full cart will probably run on it for an hour or so.
    Steve Sherrick
    Chief Collaborator
    Modern Vintage Media
    STEVESHERRICK.COM
    Local 600 DIT/Operator
    Mar 2009
    Burbank, Ca
    Hard to figure the thinking behind this thread...
    Even if you can run a MacPro DIT cart for an hour or so on batteries, what do you do on-set once your battery is dead and you have no AC?
    Senior Member Pawel Achtel's Avatar
    Oct 2007
    Tasmania
    I use electric scooter heavy duty NiMeHy batteries. They are not as heavy as deep cycle lead acid batteries, they last much longer (about 5000 cycles) and provide plenty of power.
    Pawel Achtel B.Eng(Hons) M.Sc
    www.achtel.com
    Sharp to the Edge
    Land and Underwater Cinematography, Production and Equipment | DeepX - the world's only 5k underwater housing for RED Epic and Scarlet | 3Deep - the ultimate 3D underwater housing - available in US and Europe from Band Pro
    I have a couple of 110 Ah marine batteries set up in my van. They're connected to a charger/inverter from Studer, which means I can connect it to land power (when available) or run off of the van's generator if need be. The batteries should provide me with enough power to run my Mac Pro, monitor and a my disk array for at least 3 hours - but if I'm a pinch I can always start the van up. What I like about the Studer is that it switches over between land-power and the batteries in milliseconds without interruption - so everything keeps running when the gaffer shuts off the genny ;-) As a side bonus it also smooths out the power coming in, which for those big gennys, can be real nasty to sensitive electronics.
    Tony Lorentzen, Kinema Follow me on Twitter: kinemadk
    Freelance RED Tech, DIT & Workflow wizard, Partner in VBag, Owner of RED EPIC-X #420
    Junior Member
    Oct 2011
    Quote Originally Posted by joe hedge View Post
    There are situations where you have no access to power or need to be self sufficient. I admit it is not ideal to run off of battery alone but there are situations that call for it.
    I will end up getting a small generator but wanted to investigate battery options for when using a generator on set would be prohibitive because of audio.
    The eu2000i generator is a very quiet Honda Genny with clean power that you can run your DIT cart from. It works in the US.
    The eu1000i is probably enough and is very compact.
    Regards,
    Paul Engstrom
    RAW CAMERA CO.
    boutique Epic rental, on/near set & post-production service, elite training
    Optimally Accessorized Epic Camera packages for movie, television and commercial productions
    Arri Master Primes, Arri Ultra Primes,
    Fujinon Cabrio Zooms, Angenieux Optimo Zooms, Arri Alura Zooms
    Arri MBs, Bright Tangerine MBs, Arri FF4s, Preston FIZ, Oconnor 2575s + everything you need
