Click here to go to the first RED TEAM post in this thread.   Thread: REDCINE PRO X 15 release / 16 Beta
Page 6 of 10 FirstFirst ... 2345678910 LastLast
Results 51 to 60 of 92
  1. #51
    Sep 2007
    Vancouver, BC
    Quote Originally Posted by Grant Limberg View Post
    Shaun,
    There's a fairly simple workaround for this issue. Open up preferences, then click 'OK'. The second monitor will work then.
    The dropdown shows the number of additional monitors other than the primary, not the total number of monitors connected to the system.
    Hi Grant, I did try that initially too, it still didn't work for some reason. I just reinstalled v15 again and without needing to do anything it's working now. Many thanks.
    Jun 2009
    Los Angeles, CA, USA, Earth, Solar System, Milky Way
    I found a bug that I've been able to reproduce multiple times. If I have a folder structure of R3D's, such as multiple days compiled together in folders Day_1, Day_2, and so on and select one of those folders in the Browser tree with Scan Depth higher than 1 (I usually use 3), RCXP will include one or more clips from the other folders in the Project section. For example, I click on Day_1, but I'll see a clip from Day_8. I have a collection of R3D's from various sources organized in folders, and it will even include random clips from folders higher up in the tree.
    I noticed this a few times with Build 14, but it's happening even more with Build 16. I fix it by clicking onto a different folder and then back onto the folder I want so it refreshes the scan.
    EDIT: I should probably give info about my system. 2 different Retina MBP's, one running both Lion and Mountain Lion and the other running only Mountain Lion. R3D's are on an external OWC Qx2 RAID connected via eSATA using a LaCie TB eSATA hub.
    Jan 2009
    New Orleans
    Two tiny changes I'd really love to see:
    1.) Clicking the slider for a setting should "bring focus" to it, allowing arrow key adjustment. Currently this only happens if you click the numerical value.
    2.) Clicking the slider OR numerical value for a setting should highlight its numerical value, allowing it to be replaced with the number pad. Currently you have to TRIPLE click the numerical value to do this (double click only gives you the digits before or after a decimal).
    Related bug: Neither number pad nor arrow key entry work for ISO.
    v15 can't output MXF files correctly as it can't output all the selected files and only outputs a random amount. It also puts them into separate folders which is a nightmare workflow wise.
    v14 is also very buggy at output all the clips in the bin to MXF and I have to go through manually selecting the clips it forgot to output. I thought this issue was because I was using RedLine (which is freaking great) but its not.
    Stuck in transcoding hell at the moment with something that should be automatic taking up a lot of my time behind the machine trying to babysit it.
    Rory Hinds
    Director / DoP / Colourist
    Mine Films & Mountain DI
    http://www.minefilms.com
    UK, USA, CANADA, EUROPE & SOUTH AFRICA
    IATSE 669 Director of Photography
    VFX, Grading & Finishing
    Feb 2008
    UK
    FYI
    I had a problem in v16 beta: the drop down menus for normal/anamorphic | resolution | Fit (size) and 2D/3D were greyed out so I could not change any of these options. I went to v15 to render out the file I am working with. v15 seemed more responsive all round and those options were available..
    thanks for the updates!
    peter
    Mar 2011
    Southern California
    I love the dynamic subfolder feature for exports, but it's not working for me at all. I have tried a few different metadata options, as well as variations on a simple name:
    clips
    /clips
    clips/
    /clips/
    /clips/|date|
    /exports/|reel ID|
    No matter what I choose here, the exported clips all go to the base output folder. No subfolders are created. Anyone else notice this?
  7. #57 BurnIns
    The majority of the metdata still does not work in the burn in, its available in the drop down, but does not display on output - pretty much anything which does not display an example below the drop down - Lens, focal distance, aperture, etc.
  #58
    Red Team Grant Limberg's Avatar
    Apr 2011
    RED HQ
    Christopher: The metadata you mention, Lens, Focal Distance, and Aperture require the lens to be able to communicate that data to the camera. Not all lenses are able to do this. If the field is blank when viewing the metadata on the clip itself, the burnin will also be blank for that field.
    Grant Limberg
    - "Chuck Norris never gets a syntax error. Instead, The language gets a DoesNotConformToChuck error."
    Jan 2009
    New Orleans
    Grant, ability to enter that information manually on the camera like many of the latest DSLRs would be a great idea for a future firmware :)
    Sep 2008
    Indianapolis
    I was exporting some Tiff snapshots from RCX Pro 15 this morning. After several good ones, I had a situation where the stills weren't showing up in the folder I had selected in Preferences. Thinking that RCX was sending them someplace else, I did a search and found that they hadn't been saved anywhere. When I tried to quit RCX, I got a dialog asking if I wanted to cancel the export. I clicked no and let it sit for about an hour, in case it really was still trying to export my stills. No luck there, so I turned on verbose logging and saved a log. Quitting and restarting RCX seemed to fix the problem. Everything else was operating normally within RCX, even the shutter-click sound effect when I saved a snapshot.
    If you're interested, I'll send in the log–just let me know.
    Mike Yonts
    www.mikeyontsfilms.tv
    Epic-X 1885
