Thread: BAFTA Guru interviews
Results 1 to 7 of 7
  1. #1 BAFTA Guru interviews
    Senior Member James B.'s Avatar
    Mar 2011
    Hi
    Might be obvious to some, but I'm perplexed as to how the continuity in audio was achieved in these interviews. One example
    http://guru.bafta.org/stuart-hillike...ni-masterclass
    The lighting dramatically changes on every cut, but even though the cuts sometimes happen mid sentence, the audio transition is seamless.
    What makes it puzzling to me is that the dialogue seems unscripted, though I doubt that it is. Are the people being interviewed reading off some sort of teleprompter so that their dialogue matches exactly on subsequent takes, or??
    My latest work
    [twitter] eco_bach
    "...all improvisation is life in search of a style."
    - Bruce Mau,'LifeStyle'
    Jul 2009
    New York
    Two camera shoot, with the CU shot's white bg removed in After Effects perhaps...? Not sure tho.
    Dec 2008
    San Diego, CA
    Looks like a classic key to me.
    Senior Member jimhare's Avatar
    Sep 2007
    Sydney Australia
    Given the camera angles they could have just had a black background off to the side, which would be the only thing that camera would see.
    My guess is it was shot as one, either keyed or using two backdrops in different positions.
    In other words, no audio editing at all ironically enough given your questions was about audio and the subject matter is audio!
    Senior Member Liam Hall's Avatar
    Nov 2007
    London/Worldwide
    Quote Originally Posted by James B. View Post
    Hi
    Might be obvious to some, but I'm perplexed....
    You're looking for complexity where there is none. This is a very simple two camera set-up with a white paper backdrop. The lighting is EXACTLY the same between the two cameras, though the 'B' camera looks poorly underexposed to me. What creates the drama is that in the main camera you can see the white backdrop whist the 'B' camera is shooting off he side into darkness. No secret sauce here.
    I make stuff.
    www.liamhall.net
    Mar 2011
    Toronto, ON Canada
    Most definitely all in-camera edit here.
    ___________________________
    10 frame handles
    Vimeo
    EPIC-X "SHAI"
    Liam is spot-on, and at 4:24 there is an angle that shows the white backdrop and the black background where they meet.
