Thread: EPIC AND APPLE COLOR
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1 EPIC AND APPLE COLOR
    Junior Member
    Aug 2009
    LONDON
    Hey There,
    I have a short sequence in FCP using 720 LT offline clips. I want to grade the sequence in apple colour and can't work out a way.
    I also have the light version of davinci light but i don't think the light version handles R3D files.
    I can reconnect the sequence in redline x pro to the r3d's but then any attempts at making a xml/edl for colour fail.
    any help would be greatly appreciated
    Senior Member Mathieu Ghekiere's Avatar
    Jan 2007
    Belgium
    The light version of DaVinci supports R3D, but has an output resolution limit of 1920x1080.
    Can't help you with the other questions, though.
    Senior Member Kevin Marshall's Avatar
    Jul 2009
    Frederick, MD
    DaVinci Lite would totally work (I use it with R3Ds al the time) - but you'll just be limited to mastering at 1080p. You can also bring it into Color, assuming the filenames of the offline clips match the R3Ds. You just need to swap the .mov in the xml to .r3d - either using a tool like Clipfinder, or my favorite...find & replace in TextEdit. Then import that xml into Color, and you should be set. Just make sure you have the latest Color plug-in from Red.
    That said, I still recommend Resolve if your delivery is 1080p or less. Having used Color for years, Resolve is just more fully featured, and less buggy.
    Member Matt Gerard's Avatar
    Dec 2011
    Minneapolis, MN
    Yep, the lite version handles r3d's, been playing with it for the past couple days. I'm not sure about conforming, but I've edited a seq in premier of r3d files, exported an xml, import to davinci and there it is. start grading. I've neer even opened color. Actually, that's incorrect. I opened it, looked at the interface, said WTH?!? and closed it. Our shop never has done any color correction outside of Final Cut before (no need to) but now with our EPIC, there is a need to.
    Dec 2010
    Toronto
    What's the max resolution that Colour Supports? 4k? Does it work with Scarlet/Epic/DSMC footage or just R1 and R1mx?
    Senior Member Drew Baird's Avatar
    Feb 2009
    Austin, TX
    Color works with 4k (not sure about higher) Scarlet and Epic files. I had to use color to render out a 4K CC'd trailer to show in a theater. My workflow was this:
    Premiere pro--->export to REDCINE X to connect files--->Export from RCX with quicktime wrapper and FCP XML--->Import XML into FCP--->Send to Color
    I'm not sure if FCP was a necessary step or not, but it was the most successful attempt that I had. Everything was cake once it was in Color.
    Hope this helps!
    Scarlet-X #766 "Peffercorn"
    facebook.com/The.Last.of.The.Independents
    www.andrewscottbaird.com
    Senior Member Paul Provost's Avatar
    Aug 2008
    I think with the new plugin, anything over 4k (4.5, 5k) is scaled in half so you end up with 2.5k out of epic.
    Colorist | Hollywood, CA | www.4kfinish.com
    Senior Member Justin Chin's Avatar
    Aug 2008
    Oakland, CA, USA
    Sam, check the Red.com support section and download the FCP kit. I just did this for an Epic 4kHD shoot and it worked great. Read the instructions in the white paper. It will walk you through the process.
    justin chin
    infinite machine
    www.infinitemachine.com
    Jun 2009
    Los Angeles, CA, USA, Earth, Solar System, Milky Way
    Quote Originally Posted by Paul Provost View Post
    Paul is correct. You'll lose a lot of resolution in Color too. Best option is the full version of Resolve.
    I did a workflow recently as i wanted to eventually output at 4K, there may be something in there to help you out hopefully :-)
    http://www.orensis.com/red4k.html
