Thread: Sennheiser MKE-400
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. #11
    Atlanta, Georgia
    Quote Originally Posted by miguel.mesas View Post
    Hi James, did you solve the problem? I have the same problem.
    TKS
    I did not. I did find out that the Sennheiser does have a stereo plug (read that in the manual). I believe that could be the issue. When put the plug in the camera halfway I get static, all the way...nothing. BTW, I purchased this for my 7D, for a scratch track, I just want to see if it would work.
    James Bridges
    Scarlet #651 "Maggie"
    www.typeamedia.com
    Dec 2007
    Norwich, CT. USA
    True, the Sennheiser has a stereo plug. But - it is not wired the same as the Scarlet.
    In the Scarlet Manual, Page 160;
    The audio connector pins are listed as T-R = mic + (positive) & - (negative) with the sleeve = ground.
    Since the mic was catering to the DSLR market, the Sennheiser has the Tip and Ring wired the same as mic L and mic L, with the sleeve = Ground.
    So both Tip and Ring carry the same, left channel signal.
    ________________
    Sent that info to the contacts at Sennheiser that I mentioned earlier (plus another) Jason just responded:
    The problem is likely because of the dual mono wiring of the MKE400. A stereo to mono 1/8" adapter may be the solution.
    Let me know if this helps.
    Regards,
    Jason Kelly
    Product Specialist,
    Wireless Systems
    Sennheiser Electronic Corporation
    Phone: 860-434-9190 x107
    Email: jkelly@sennheiserusa.com
    __________________
    After you try his suggestion, post your results. I personally do not own the 400 so cannot test it myself.
    Hope this is an easy solution.
    Cheers!
    Dec 2007
    Norwich, CT. USA
    Had some further follow-up with Sennheiser (I'm in communication with them often)...
    They asked that I post this for the time being:
    Due to the unique connector and wiring scheme of the Scarlett camera, the MKE 400 with its standard cable will not operate. We are investigating an adapter cable and will keep users posted on developments. Thank you.
    Joe Ciaudelli
    Director, Advanced Projects & Engineering Services
    Sennheiser
    860-434-4547 office
    Atlanta, Georgia
    Hey Brian,
    Thanks for the follow up. It's one of those thing. Going to purchase a better mic and hook it up to the A-Box.
    James Bridges
    www.typeamedia.com
    Dec 2009
    Chatsworthless, CA
    Excellent idea. The older Sennheiser MKH-416's are extremely plentiful, and it was (and still is) a standard camera-mounted shotgun used by literally thousands of crews worldwide. They pop up used on eBay all the time. Great mike, a real workhorse.
    www.cinesound.tv | location sound / post-production consultant
