Thread: Workflow Question: FCP 7 with Atomos Samurai to RCX
Results 1 to 5 of 5
  1. #1 Workflow Question: FCP 7 with Atomos Samurai to RCX
    Jun 2008
    Munich, Germany
    Hello!
    ...could anyone explain the workflow how to get my edit from FCP 7 with Atomos Samurai Proxies back to Redcine X?
    Many thanks for your help!
    Christian
    Christian Felder, Freelance Camera & Postproduction
    Red Epic X #1335
    Good question. I'd like to hear about it too. The Samurai carries the camera timecode on in the prores files so maybe export an EDL from your timeline into REDCine X and see what happens. Just make sure all your source media are present somewhere that REDCine X can see it and muck around with the EDL export settings from FCP and also with Redcine X import settings. Good luck
    Senior Member Mike Garrick's Avatar
    Sep 2011
    Australia
    Does Samurai files now carry the same tags as R3D camera files ? If it does it should be pretty simple.
    Mar 2011
    Toronto, ON Canada
    Not yet.
    Quote Originally Posted by Mike Garrick View Post
    ___________________________
    10 frame handles
    Vimeo
    EPIC-X "SHAI"
    Braunschweig, Germany
    Hmm, why shouldn't it work with Samurai? It works for me with KiPro Mini, and that doesn't even have an offset compensation, so I do need to compensate in post.
    Regards,
    Uli
    My Red is called Vertov after a Russian avantgarde filmmaker, a pioneer in modern cinematography, a true revolutionary who later suffered under Stalin's bureaucracy.
