Click here to go to the first RED TEAM post in this thread.   Thread: epic antenna upgrade DOES NOT WORK
Page 1 of 2 12 LastLast
Results 1 to 10 of 17
  1. #1 epic antenna upgrade DOES NOT WORK
    May 2007
    Bruxelles, Belgium, Europe
    just installed new updated epic antenna...... no more communication between redmote and epic ! latest firmware on both, installation step by step... NOTHING
    No Problem Production, Bruxelles, Belgium
    No Problem
    Senior Member Andy White's Avatar
    Nov 2010
    United Kingdom
    Maybe try replacing the new antenna with the old/original & see if that works again?
    Member Matt Gerard's Avatar
    Dec 2011
    Minneapolis, MN
    I would hazard to guess that the connection on the antenna and the cable is at fault here. I had the same issue, I had to pull the new antennae out (not an easy task, take it slow) to find that the cable dropped off the connector to the antenna. Turns out it needs a pretty hard squeeze to get the thing to click on. Make sure its lined up well before trying to pop it on, looking at it you could knacker the connector on the cable pretty easily if its crooked when you try to squeeze it on. Mine works pretty well, I'm now getting 50' + through 2 walls before the signal disappears.
    Senior Member Antony M's Avatar
    Jul 2009
    Sussex, England & Sachsen, Germany
    I have done the install too. My RedMote connects.
    But I still have a very limited range.
    Up to 2 feet away, I get full green bars.
    More than 3 feet away I only have yellow or red bars.
  5.   Click here to go to the next RED TEAM post in this thread.
  #5
    Oliver, we received the email you sent to upgrades@red.com this morning and we will walk you through troubleshooting this issue.
    NICK
    Senior Member Andrae Palmer's Avatar
    Aug 2007
    Fort Lauderdale, FL
    Quote Originally Posted by Antony M View Post
    I don't think the signal meter is working very well... but the connection is lasting upto 50 feet away in my tests.
    Andrae Palmer
    Founder, FACETMEDIA LLC
    facebook.com/facetmedia
    Package for rent in South Florida with EPIC-X Camera #721 & RED One #6353, RPP, RED Rocket, RED 18-50 & Oconnor 2575C. Davinci Resolve, FSI LM-2461W & Mac Pro 12 core. Rentals/Equipment List: http://facetmedia.com/red-rental/
  7.   Click here to go to the next RED TEAM post in this thread.
  #7
    Red Team Stuart English's Avatar
    Irvine, Ca
    ..... the connection is lasting up to 50 feet away in my tests...
    This is the expected performance ... so if you have a unit that does not deliver at least that after performing the antennae upgrade, then connect RED tech support.
    Workflow Wizard
    Aug 2009
    Lakewood CA
    Have you tried doing the "Rediscover Hardware" in the "maintenance" portion of the menus???
    Aug 2007
    Fort Lauderdale, FL
    Quote Originally Posted by Stuart English View Post
    Stuart,
    Do you know why the old design was a board with circuits and this one is just a plain aluminum antenna?
    Andrae Palmer
  10.   This is the last RED TEAM post in this thread.   #10
    Irvine, Ca
    Apparences can be deceptive Andrae :-)
    ... the bottom line is the "uncertain range issue" ascribed to the REDmote, is in fact resolved here.
    Workflow Wizard
