Thread: MP4 Calibration
Results 1 to 8 of 8
  1. #1 MP4 Calibration
    Another question on calibration and monitoring.
    My business is producing and selling photos and videos, which are distributed entirely online. Currently the format of choice is full HD 6 Mbps H.264. I edit in FCPX, grade in Resolve from the original R3D, output to a ProRes HQ "master" back to FCPX to reunite with the audio, then prepare H.264 MP4 clips using Compressor for sale from the ProRes.
    Is there any sensible way to approach calibration and monitoring when the final destination is online?
    I know it is quite "bargain basement" to you guys aiming for the cinema screen!
    However I've got an insatiable fetish for image quality which means I really want to make sure the final version looks as good as possible for as many of my customers as possible, even given the constraints of online distribution. I don't want to throw my hands up and despair.
    Clearly, if one is heading for cinema or TV as one's final output, a properly calibrated broadcast monitor is the correct solution. But the fact of the matter is that my customers will only see the films on a TV if they burn a DVD or Blue-ray for themselves, which they don't. The vast majority of my customers are watching on cheap computer monitors or iPads/iPhones/etc.
    I'm not convinced in this scenario that a broadcast monitor is actually the correct solution. Surely the best one can hope for is that it might sit sorta in the middle of the variation of people's computer monitors? Broadcast standards don't actually seem relevant since at no point does the video ever reach a broadcaster, DVD or TV screen.
    I'm grading with an Apple 30" cinema display calibrated with a Colour Spyder 3. My only aim doing it that way is to get my monitor somewhere in the middle of the vast variation in screen properties that my viewers will be seeing the footage under. I'm under no illusions that this method is capable of any sort of rigour.
    On the plus side, I can say that my informal test shows it works OK. Whenever I get chance to view some of my work on a random PC at a friend's house, I do so. I sometimes find people with extraordinary settings on their monitors- the most common being the contrast and brightness whacked right up and the white balance at eyebleeding levels of blueness. But those aside, my stuff usually looks acceptable most places I view it.
    On the minus side, I'm operating largely in the dark, except to say that FCPX seems to have fixed QT gamma shift issues for me.
    Anyone got any clues? Is there a better procedure?
    Cheers, Hywel.
    Feb 2010
    Helsinki, Finland
    When doing stuff for online use I check it on a monitor calibrated to to a basic sRGB target, which tends to be sRGB primaries with D65 white point, 2.2 gamma and 120cd/m^2 brightness, which I would assume is what your Spyder 3's calibration software offers by default. So I don't really see anything to change in how you're doing things when it comes to color.
    Senior Member Luis Otero's Avatar
    Orlando, FL
    I agree 100% with Jaakko's explanation,
    Luis Otero
    Epic-X #1616
    (Old Red One 711)
    I was scammed, and I love it...!
    Digital Emulsion
    Orlando, FL
    IMDB: www.imdb.com/name/nm3889059/
    Senior Member Mike Lary's Avatar
    Mar 2011
    Seoul, South Korea
    Quote Originally Posted by Hywel Phillips View Post
    You can monitor your transcodes to make sure the end result viewed on your calibrated monitor meets your expectations. You can't really calibrate your display for web because there is no consistency between displays or a standard that is followed. Most displays are not calibrated and they have dissimilar gamuts. Uncalibrated monitors generally use an ICC profile provided by the manufacturer that is optimized for that model monitor (not to a known standard). Because the profile is made from averaged data for a particular model it's accuracy is highly dependent on manufacturing consistency. Ambient lighting conditions vary greatly. Different web browsers render color differently. Different media players render color differently. Then there is the end user factor that you mentioned: display control settings tweaked to a particular person's liking.
    Mike Lary
    Director of Technology, DIGITAL FACTORY, Seoul
    Digital Revolution Since 2009
    Color Correction/Digital Workflow/Red Camera Rental
    www.DigitalFactory.kr
    HI,
    Thanks guys. Nice to know I'm not missing a major trick anywhere :-)
    Cheers, Hywel
    Orlando, FL
    Quote Originally Posted by Mike Lary View Post
    ... You can't really calibrate your display for web because there is no consistency between displays or a standard that is followed...
    The standard is called sRGB, and the monitor can be calibrated to such gamut.
    Luis Otero
    Epic-X #1616
    (Old Red One 711)
    Digital Emulsion
    Orlando, FL
    Mar 2011
    Seoul, South Korea
    Quote Originally Posted by Luis Otero View Post
    Luis,
    I said there is no standard "that is followed". As for sRGB, that's an old standard that does not reflect the behavior of current display technologies.
    Mike Lary
    Orlando, FL
    Do calibration very often (weekly) to my monitors, and is not unused or forgotten standard. I calibrate for film-LUT, and other standards based on client final product destination. Today more than ever, sRGB is a final destination due to web centric distribution.
    Luis Otero
    Epic-X #1616
    (Old Red One 711)
    Digital Emulsion
    Orlando, FL
