Thread: Red Rocket errors with 3.2.16 / 3.2.13 clips
Results 1 to 6 of 6
  1. #1 Red Rocket errors with 3.2.16 / 3.2.13 clips
    Clips captured at 5:1 or 3:1 with Epic 3.2.16 or 3.2.13 have decode errors using Red Rocket (Driver: 1.4.27.0)
    Clips playback/transcode fine using software decode (rocket disabled)
    Not all clips exhibit this problem, only when there is a large change in the scene, rack focus, etc.
    Verified problem on multiple rockets/workstations - its thankfully not the dead rocket for no reason problem.
    3:1/5:1 clips from 3.07 seems fine with the rocket.
    Trouble ticket filed, and problem verified, hopefully this will be fixed soon.
    Jul 2007
    Culver City, CA
    I am curious if anyone else has experienced this issue with the Red Rocket and 3.2.16?
    Chris do you have any follow up?
    I would really like to use 3.2.16 on a shoot that starts next week. It seems solid to me in my initial tests.
    Thanks in advance.
    Mick
    Feb 2007
    Austin,TX
    I shot 2 cameras for 4 days solid last week on the latest build. No problems on several terabytes of footage.
    Major commercial client.
    http://shanefkelly.com
    Epix-X#607
    Wise men talk because they have something to say; fools, because they have to say something.
    Plato (427 BC - 347 BC)
    Red support duplicated the problem I am seeing, No it has Not been fixed.
    I only see problems at 3:1 and 5:1, and only when using the rocket, and again not every clip - only highly detailed clips with significant motion.
    So if you shoot with compression ratios greater than that or are not using the rocket you are ok, probably.
    They have not said if its a problem with rocket software or the camera firmware.
    We almost always shoot 3:1 so this is a big problem for us.
    Just did some some tests with the F65, may start using that for awhile, if only it wasn't so big.
    Senior Member Paul Russell's Avatar
    Sep 2011
    Malaysia and Singapore
    I've had lots of problems rendering out 5K footage shot on 3.2.16 at 7:1 using Premiere CS6 or AME on W7. Slow renders and frequent hangs mid project, regardless of whether rendering to H.264 or Cineform codec. The only plugins being used on the footage are the native source adjustments and curves. It's very annoying when you've set a bunch to render overnight and the next morning you find that the first one jammed halfway in and stuck the whole queue.
    Junior Member Josh Wallace's Avatar
    Jun 2009
    Bristol, U.K.
    Anyone confirm if this issue is still with us v3.2.19?
