So when I DIT & transcode, I use a Glyph Triplicator & a Maxx Digital Red Rocket.
Right now I'm on a show and my setup is this,
17" MacbookPro 2011 Model
Maxx Digital into the PCI-e slot of the Macbook Pro
Macbook Pro FW800 cable going into the Triplicator which is hooked up to (2) eSATA Lacie External Drives via eSATA. Red-Mag reader is hooked up to the FW800 port of the Triplicator as well.
Moving 22GB of data, it's taking 9 minutes, 54 seconds. Keep in mind it's spanning across 2 drives via the triplicator.
Transcoding to 1080P Pro-Res HQ is taking 17 minutes, 34 seconds.
I just bought the Lacie eSATA Hub to speed things up. Now my setup is this....
Macbook Pro Thunderbolt to HUB. eSATA out of the HUB to the Triplicator. eSATA out of the HUB to the Red-Mag reader.
Moving the same 22GB of data, it's now taking 2 minutes, 35 seconds!
Transcoding to 1080P Pro-Res HQ is taking 17 minutes, 21 seconds.
Not much of a speed improvement on the transcodes but the transfer speeds are now lighting FAST. I'm guessing the slow down on the transcoding is because of the PCI-e slot. I imagine a thunderbolt enclosure would be a lot faster but I'm more than happy with these results!
Go get one! It's $200!
