Click here to go to the first RED TEAM post in this thread.   Thread: Release Camera Build 3.2.16
Page 1 of 19 1234511 ... LastLast
Results 1 to 10 of 189
  1.   Click here to go to the next RED TEAM post in this thread.
  #1 Release Camera Build 3.2.16
    RELEASE VERSIONS :)
    SIGNIFICANT CHANGES SINCE PREVIOUS BUILD V3.0.7:
    • Added 5K HD, 3K HD, 2K HD, 1K HD formats
    • Added 1K WS format (Epic 400fps, Scarlet 120fps)
    • Added Target REDCode feature
    • Added Post Record Fan Delay (max 1 minute)
    • Added 1-camera to multiple REDMote support
    • Added Slate Information Dialog
    • Added User RGB curves capability
    • Added RMD file import/save/apply
    • Added Gyro support
    • Added Side Handle Key Lock Feature
    • Added Audio Gain/Limiter Controls
    • Added Phantom Power Support(Hardware Rev Dependent)
    • Added External record mode
    • Added Force Restore Feature using Power Button
    • Added HD-SDI Format controls
    • Added 9" LCD Touchscreen support
    • Added Dual Battery Module support
    • Added Rear SSD Module support
    • Added OLED EVF Brightness support
    • Added Playback Frame, Title and Action Guide status
    • Added PL Lens short circuit detection
    • Added HDMI 1080p/720p refresh rates of 24,25,30,50,60
    • Enhanced Keys assignment dialog
    • Enhanced Preset dialog
    • Enhanced Playback load notifications and error handling
    • Enhanced UI usability
    • Enhanced AF capability
    • Camera Name defaults to camera type (i.e., SCARLET/EPIC)
    • Fix for Playback using EVF
    • Fix for Playback support of 5K and 5K ANA
    • Fix for Zoom Rocker +/- Mapping
    • Fix for HD-SDI output scaling
    • Fix for LCD image ‘stutter’ when panning
    • Fix for camera freeze when changing AF/MF with Focus dialog open
    • Fix for Zebras disappearing after disconnect/reconnect of RED monitor
    • Fix for scaling of 5K clips during Playback
    • Fix for HD-SDI test pattern output levels
    • Fix for record error 0×00001E seen on some cameras
    • Fix for multi-clip load issue in Playback
    • Fix for audio in HDRx mode
    • Fix for frame drift with Sensor Sync = Genlock on some cameras
    • Fix for camera not completing clip recording to end of media
    • Fix for camera hang mapping actions to rocker switch
    • Fix for LCD w/half white screen on start-up
    • Fix for RED EVF connection problems
    OPERATIONAL NOTES SPECIFIC TO BUILD V3.2.16:
    • Sensor Flip disabled
    • Detaching monitor during playback will require reboot on monitor re-attach
    • Camera powered by RED BRICK may display voltage instead of battery capacity on some cameras.
    • EVF black level raised in some cases
    • ISO setting limited to min of 250
    • Image Magnify is available during preview, but not during recording.
    • HD-SDI is True Progressive and does not support 1080i or 1080 PsF signal formats.
    Epic Build : http://s3.amazonaws.com/red_3/downlo..._3_v3.2.16.zip
    Scarlet Build : http://s3.amazonaws.com/red_3/downlo..._3_v3.2.16.zip
    Will be on RED.COM in the morning..
    Member Matt Mascheri's Avatar
    Sep 2008
    Chicagoland
    Impressive. Most impressive.
    Matt
    Matthew Mascheri
    Dome3D LLC
    Web - www.Dome3D.com
    RED Videos (among other fulldome stuff) - http://www.vimeo.com/dome3d/videos
    Mar 2011
    Toronto, ON Canada
    nice :-)
    How's the power management and LCD flip going? hee hee.
    ___________________________
    10 frame handles
    Vimeo
    EPIC-X "SHAI"
    Senior Member Michael Mayda's Avatar
    Oct 2007
    Sacramento, CA
    Thank you for another batch of goodness.
    Michael Mayda, Forensic Imaging; Epic X #00653; Epic M #00922; Red MX #1976
  5.   Click here to go to the next RED TEAM post in this thread.
  #5
    Power management is coming along.. high priority. You will see little small steps instead of one big step as builds go along.
    Jan 2008
    WOW !!!
    This is a great Update Jarred... Very significant updates in there.
    Thanks again. (as usual)
    Mark Toia
    www.toia.com
    www.zoomfilmtv.com.au
    Mar 2011
    Toronto, ON Canada
    Awesome... thanks! Already excited the OLED takes 70% less power.
    Quote Originally Posted by Jarred Land View Post
    10 frame handles
    Vimeo
    EPIC-X "SHAI"
    dude =] perfect timing for me, thanks!!!
    Senior Member Jim Hoffman's Avatar
    May 2007
    Great. And the official release build too. Thanks.
    Jim Hoffman
    Chicago, Illinois
    Senior Member Trevor Meeks's Avatar
    Jun 2009
    Sonoma, CA
    Wow... awesome. Thanks Jarred and everyone on the RED Firmware team!
