Click here to go to the first RED TEAM post in this thread.   Thread: Where are my RMDs?
Results 1 to 10 of 10
  1. #1 Where are my RMDs?
    Norway
    Working on a project, and all of a sudden RMD's are notr generated. (RCXP 14)
    The grades are saved (somewhere) but not in the r3d folders.
    But then no other app can read them.
    Wassup?
    G
    Life is good. So is RED...
    http://youtu.be/mhFB1CMzQBM
    http://bit.ly/mCwcoN
    Twitter: gunleik
    Norway
    OK, so force manual save RMDs seemed to work, but why didn't it not just save them as it should have?
    Twitter: gunleik
    Senior Member Nick Pasquariello's Avatar
    Dec 2010
    Providence, RI
    The past few versions of RCX have been saving my RMDs to a single location, rather than within each clip folder like they used to. It hasn't been an issue for our workflow yet since we rarely link back to the RMDs in other programs. But I am confused as to why I can't save the RMDs to the clip folders and instead have to pool them all together in one location.
    Icarus Rex Productions
    Scarlet #1798 "Ariadne"
    Norway
    Yes. That is a bad choice.
    But I have more issues...
    I'll have to update my RAW workflow thread... :)
    Twitter: gunleik
    Apr 2011
    RED Headquarters - Irvine
    Quote Originally Posted by Nick Pasquariello View Post
    Nick,
    Have you setup a master RMD directory?? If so then that's why all your RMD's are saved to a single location. If you want then saved within each clip folder you'll have to disable that feature in the preferences window.
    Armen
    Yesterday is history, tomorrow is a mystery, but today is a gift; that's why it is called the present.
    Dec 2010
    Providence, RI
    Quote Originally Posted by Armen Shandi View Post
    Nick,
    Armen
    Thanks. Wish the preferences pane was a bit clearer on that. To me, the preference pane indicates "You can either save your RMDs to this master location, or NOT AT ALL."
    Norway
    Mine weren't in a master directory, BTW, they were just not there untill I manually chose to make them.
    The bigger issue is that resolve used the first for the full edit...
    THAT was a bad choice.
    Have contacted BMD about that. And it happened once before, but then I thought it was all my fault. THis time I know it sn't...
    G
    Twitter: gunleik
  #8
    Red Team
    Sep 2009
    Irvine, CA
    Gunleik,
    Can you back up your preferences file (/Users/{user name}/Library/Application\ Support/red/RedCineX/Preferences/Preferences.ini) and send it to redcinex at red? Then you can remove the original
    and see if that fixes your issue (RCX will generate a new file). I'm wondering if you had some sort of preferences conflict.
    Thanks,
    David
    Norway
    OK. Thanks. Will try that tomorrow! (off work now)
    Any idea why resolve acts badly occationally with RMDs? (Know you're not BMD...)
    Twitter: gunleik
  10.   This is the last RED TEAM post in this thread.   #10
    Red Team
    Sep 2009
    Irvine, CA
    Sounds good, thanks. Nope sorry, but if you find out let us know!
    David
