Thread: Best Top Handle Solution?
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. #11
    Senior Member Justin Chin's Avatar
    Aug 2008
    Oakland, CA, USA
    I pretty much do the bjorn combo. But instead of the red nato rails I use the x ones (because I like the spring loaded safety pins). But my configuration is a little more expensive because I have to use this (Rosette Adapter) to attach the wooden nato rail. The Red Rosette Adapter is a clean solution (but without the safety pins).
    justin chin
    infinite machine
    www.infinitemachine.com
    Junior Member Mike_C's Avatar
    Jun 2011
    Singapore
    I use the red swat rail to hold the sliding handle and mount the display directly to the handle. I removed the rosette from the front of the handle and use a single screw as you can't use the 2 screws (holes 2 and 4 of the 5 holes in the monitor mount) because they are threaded, and the holes in the sliding handle are threaded, and the monitor wiggles a bit.
    Not the most elegant, but cheap and works. (obviously the side handle is not required)
    I will try to post a photo:
    Jun 2011
    Singapore
    Quote Originally Posted by Mike_C View Post
    One additional followup. With the monitor locked to the handle, I can very quickly click off the handle and throw the camera in my lowe backpack. Again this is not a bulletproof pelican case but for popping around town etc I find it the most handy way to quickly set up, take some shots, then pack up.
    Nov 2009
    Quote Originally Posted by Björn Benckert View Post
    The red top handle with a: http://www.red.com/store/products/ro...guide-adaptorn
    on the front of the handle.
    and a: http://x.com/nato-clamp
    on the monitor is really nice.
    Then you can take of the handle and also mount the monitor on handle or directly on the rail that goes ontop of the camera (that comes with the handle)
    What would the ROSETTE-TO-SWAT RAIL ADAPTOR be typically used for?
    Aug 2008
    Oakland, CA, USA
    Quote Originally Posted by Les C. View Post
    Anything that can be attached to a Nato Clamp. Personally like the ability to slide items on the nato rail so I can balance the camera when holding the top handle.
    justin chin
    infinite machine
    Senior Member Trevor Meeks's Avatar
    Jun 2009
    Sonoma, CA
    Quote Originally Posted by Marc Dunham View Post
    See thats what I was missing, the nato rails, was kind of confused. I like that configuration a lot
    you just bolt a NATO rail to your camera, and the RED sliding handle slides on and locks down to the rail.
