Click here to go to the first RED TEAM post in this thread.   Thread: RCX 3D Offset
Results 1 to 8 of 8
  1. #1 RCX 3D Offset
    Senior Member Kemalettin Sert's Avatar
    May 2009
    Turkey
    we shot 3D with Red Epics used master&slave giga cable and lockit generators. we had problem with sync all of the lights was green but there were 2-3 frames difference between left&right cameras.
    shot more than 40 cards and im adjusting offset frame by frame on RCX.is there any automated method for this??
    also few times we had huge problem on frames.Left camera shot 2100 frames Right camera shot 1050 frames..each clip were doubled..any solution for this? i have almost 100 clips like this..
    Sep 2009
    Ft. Lauderdale, FL
    I've experienced this recently too. My problem is that the timecode can be off by one or two frames, causing the automatic frame-offset feature in Make 3D Clip (RCX) to fail . I have an open trouble ticket at the moment - no solution yet.
  3.   Click here to go to the next RED TEAM post in this thread.
  #3
    Red Team
    Sep 2009
    Irvine, CA
    Kemalettin,
    Please file a support ticket at http://www.red.com/contact_us. This will ensure you are connected with the right team to work through the issue you are having.
    Thanks,
    David
    May 2009
    Turkey
    Thanks David i dont want to open ticket :) it takes years to get reply and in the end i will not get an answer.
    Is there any solution please reply on here...
    Member Benedict Heinzl's Avatar
    May 2012
    Vienna - Austria
    Quote Originally Posted by Kemalettin Sert View Post
    isn't that a little bit rude?
  6.   This is the last RED TEAM post in this thread.   #6
    Red Team
    Sep 2009
    Irvine, CA
    Hi Kemalettin,
    Even if we can't immediately provide a solution, it gets the issue in our system for further review. And it definitely does not take years to get a reply! For your particular case, and as David has mentioned, we are aware
    of a possible issue here and have already been looking into it. Any additional information from yourself would be extremely helpful, allowing the support team to diagnose your setup and look for potential causes.
    David
    Sep 2009
    Ft. Lauderdale, FL
    RED has been VERY responsive on this.
    -- David Cole
    May 2009
    Turkey
    Quote Originally Posted by David Ibbitson View Post
    Hi Kemalettin,
    David
    thank you david :) im waiting for it..
