Thread: Zeiss CP.2
Results 1 to 2 of 2
  1. #1 Zeiss CP.2
    Junior Member
    Feb 2010
    Copenhagen, Denmark
    05-28-2012, 05:38 AM
    Im thinking of buying the CP.2 Super Speed, ( 35,50,85mm f:1,5) but will these lenses cover the full 5K format?
    What about the CP.2 21mm & 28mm.?
    Any thoughts on wherther to buy these lenses or not?..
    Best regards.
    Mads Nielsen
    Epic-x
    Red 18-85mm
    Jan 2010
    All the focal lenghts you mention cover 36x24 full frame, so your totally fine with 5k an als with the 6k it will cover it.
    The superspeed look interesting. I don't know if someone tested them already, but i would be really interested how they hold up. The normal cp2 lenses get quite soft when full
    open, so im curious to see how they managed to get the T1.5 acceptable image quality.
    What sucks on the the 21 is the T2.9, that nearly 2 stops less then your other lenses, something to consider when buting a set...
