Thread: All Stills in Timeline
Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1 All Stills in Timeline
    I like to just scrub through a bunch of clips on a timeline and pull stills. Is there a way to export all of the stills from all the clips on the timeline?
    Gavin Greenwalt || im.thatoneguy
    im.thatoneguy[at]gmail.com | Straightface Studios | VFX & Animation
    Canon Scarlet-X package available to rent in Seattle, WA
    If I remember correctly they were going to implement a batch export of stills in a future version of RC-X Pro. Couldn't find the thread though.
    phfx.com IMDB
    Scarlet-X #316 "Skully"
    Senior Member Josh Beadle's Avatar
    Sep 2011
    SoCali
    That would move me closer to the Epic as still camera concept. Until I can use Lightroom to work the single frame R3D images . . . the Epic remains the finest movie camera on the planet
    Josh
    Epic-M 1388 aka "Black Sheep"
    ATV FamFun
    It's not your camera's fault:
    http://www.youtube.com/watch?v=jJm2EGNIod0&feature=related
    "Your first 10,000 photographs are your worst"
    Henri Cartier-Bresson
    Senior Member Jeff Whitehurst's Avatar
    Nov 2011
    Hawaii and all over the Western US
    I'm doing this with an RCX export preset set up for TIFF file format, output resolution set to clip size, Full Debayer, ask for Output Location, then apply the export preset to the timeline.
    Side note, once all the TIFFs are in a folder, I use the Cover Flow option in the OSX finder to cycle through them lightning fast by holding down the arrow keys.
    Jeff Whitehurst Scarlet-X #1177 "Pearl"
    www.jeffwhitehurst.com
    www.kipukafilms.com
    Nothing Happens Until Something Moves
    - Albert Einstein
    Apr 2011
    RED Headquarters - Irvine
    Quote Originally Posted by Gavin Greenwalt View Post
    I like to just scrub through a bunch of videos on a timeline and pull stills. Is there a way to export all of the stills from all the clips on the timeline?
    Gavin,
    You can setup an export preset (with whichever file format you want to export to); then in the frames tab enable "Export Stills Only" and save your export.
    Load all your clips you want to the timeline, scrub through and pull the stills you want from each clip; then in the export tab set to export timeline (all clips) or (separate clips) and export. This should export all the stills you've pulled from the timeline.
    Thanks.
    Armen
    Yesterday is history, tomorrow is a mystery, but today is a gift; that's why it is called the present.
    Thanks Armen that'll work!
    Now any way to *see* all the stills on the timeline regardless of what clip is under the scrub bar? I'm using timelines like 'bins'. When I start and stop rolling is kind of random.
    Also another needed feature is rotation per-cut. I'm not going to start/stop rolling necessarily to go for a portrait shot. so if I could setup rotation settings per-cut I could just cut up a clip based on which half was portrait vs landscape.
    Quote Originally Posted by Jeff Whitehurst View Post
    Attachment 25843
    Output 72GB of TIFFs in order to pull 20-30 frames? Pass. Also you lose per-image RAW settings.
    Nov 2011
    I use the TIFFs to quickly find the stills I like, then go back to RCX and pull the R3D Snapshots I want, open them in PS with full RAW capabilities. Delete the TIFFs later. BTW, you're welcome.
    www.kipukafilms.com
    - Albert Einstein
    Senior Member Tehben Dean's Avatar
    May 2009
    Portland. OR
    What Armen said.
    I would really like to be able to group all stills from a bin of clips in a "Stills Bin." I still can't figure out how to batch apply a look to all my stills unless I apply it to the clips before I select the stills which is a bit of a pain if you want to apply a preset for your tiffs before exporting them to edit.
    TEHBEN DEAN - stills & motion
    EPIC-X #557
    www.tehbendean.com
    I love to shoot beautiful things with cameras...
    Apr 2011
    Quote Originally Posted by Tehben Dean View Post
    What Armen said.
    Tehban,
    Currently in RCX it seems that a look preset can only be applied to still from clips in the timeline on a per clip basis. Send an email to redcinex at red dot com with a feature request of this option and it can get added to list of features to add. Thanks.
    Armen
    Apr 2011
    Gavin,
    Stills are saved/viewed on a per clip basis. Send an email to redcinex at red dot com with a feature request of this option and it can get added to list of features to add. Thanks.
    Armen
