Click here to go to the first RED TEAM post in this thread.   Thread: REDCINE-X crashes when submitting more than 1,000 clips to Render queue
Results 1 to 7 of 7
  1. #1 REDCINE-X crashes when submitting more than 1,000 clips to Render queue
    Hey all,
    Running REDCINE-X Build 14, and it seems that adding more than 1,000 clips to the Render queue crashes RCX. Anyone else experience this problem?
    Senior Member William Albertini's Avatar
    Nov 2011
    New York, NY
    One thousand clips? Wow.
    Yep, same here.
    Trevor Meier :: Story & Image
    http://trevormeier.com/
    http://storyspark.ca/
    Proud owner since R1 #182
    When you're on a two-camera RED doc shoot for nearly three weeks, the number of clips adds up fast!
    Update: only occurs when redline is used for the render. Everything seems to be fine without using redline. Also, using redline (even when render submit doesn't result in a crash) can be finicky: I've submitted batches of a few hundred clips, only to find that some clips didn't render out at all - i.e., I submit 394 clips for render, but I only see 364 clips in Finder once the render is done.
    For now, rendering without redline - but that kind of sucks, because only one clips renders at once. The batch is quite a bit slower going one at a time.
    Anyone know what might be going on here? I ended up finishing the transcodes by doing batches of no more than a couple hundred at a time, but it'd be great to be able to have redcine deal with this by itself :)
  6.   This is the last RED TEAM post in this thread.   #6
    Red Team
    Sep 2009
    Irvine, CA
    Still looking into it :) What format are you transcoding to?
    David
    Cool. Transcoding to Prores - specifically, 1280x540 Prores LT.
