Thread: RENDERED EFFECTS BLACK LINE PROBLEM?
Results 1 to 3 of 3
  1. #1 RENDERED EFFECTS BLACK LINE PROBLEM?
    Has anyone had trouble applying effects to a clip in Premiere CS6? When I apply any effect like a garbage matte, or flip, when I render it on the timeline the clip becomes slightly squeezed and has a black line across
    the bottom of the frame. I believe it has something to do with the REDCODE compression, because when I change the sequence setting to Quicktime, the rendered effect on the timeline appears correct.
    Is there something I'm not doing correctly or is this a bug?
    Clint Childers
    Red#846
    Senior Member John Marchant's Avatar
    May 2010
    Normandy, England
    Seems to be the iframe MPEG compression used in the Redcode preset. I'm currently using a custom preset with prores compression for previews... only way around it I can find.
    Epic Monochrome UK/EU Rental - rentmonochro.me
    Check out our showreel or talk to us @kippertieltd
    EPIC-M #549 EPIC-M MONOCHROME #1649 EPIC-X #3038
    KipperTie
    creative media for business
    That's what I had to do as well, I just wondered if anyone else was having the same issue.
    I guess until RED allows Adobe to write to R3D with their magic codec, then we'll always have to use another codec to render to.
    Clint Childers
    Red#846
