Thread: Major Audio Problems with my Scarlet
Results 1 to 4 of 4
  1. #1 Major Audio Problems with my Scarlet
    Mar 2012
    ID / WA State
    Red is currently working this problem diligently for me, but I thought I would see if anyone else had this problem.
    I can use one mic, plugged into the front of the Scarlet, perfect. I can plug the same mic into either side and be fine. I have done this with 2 dynamic mics, same model/specs. If I plug both in I get mixed results, most of the time bad. I get crackling, pops, and drop signal here and there. All this while being well under clipping due to input/volume levels. I thought it was a bad export of the footage, but I did it a few times and got the same audio. And it is in the audio files, its not playback.
    I had an audio tech look at the files and since I did many tests with different mics, XLR cables, we were able to rule out a bad mic/cable or L or R side of the camera. I also tested each mic/cable with my Zoom H4n recorder, one, then 2, with perfect results in all situations.
    I had these problems dispite being on a few different firmwares, I have had 3.0.0 and 3.2.8 beta.
    Michael Notar
    WWW.SHUTTERWORKSFILM.COM
    Video Production and Equipment Rentals.
    Dec 2009
    Chatsworthless, CA
    What specific dynamic microphone are you trying to use? What kind of connector are you using with it? Are you going balanced or unbalanced?
    I suspect there's an issue with the adapter going to 1/8" (3.5mm) mini-plug.
    www.cinesound.tv | location sound / post-production consultant
    Mar 2012
    ID / WA State
    SHURE SM 58. XLR. Balanced. I can use one but the problem is when I use to. I have a 1/8 to XLR HOSA Stereo adapter, same specs as the red one. But why is the problem there when I use two mic/adapter cables vs one. its the same thing but just each in a separate channel.
    Michael Notar
    Feb 2007
    Netherlands, Amsterdam
    Try to use a small piece of cellotape over the four pl mount connectors before you put your lens on it. It works fine with the Epic's until Red solved the problem.
    Robert M. Berger NSC
    Director of Photography
    Epic-X "ED" 00274
    www.camlight.nl
    Amsterdam
    The Netherlands
