Click here to go to the first RED TEAM post in this thread.   Thread: Monitor Flip / Flop Option
Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 49
  1. #11
    Senior Member Les Dittert's Avatar
    Sep 2011
    It's disturbing they removed the usual disclaimer : ' no sensor flip in this version'
    I get the feeling that the firmware code of the camera is in a 'spaghetti code state', and no one wants to touch that area until a significant rewrite is done.
    OR : the non-reprogram-able hardware/FPGA has been found to not support it reliably.... I hope that's not the case .
    -Les Dittert
    Senior Member Frazier Nivens's Avatar
    Oct 2007
    Key Largo, Florida
    Come on RED team, we really need this asap. What's up and is anything going to happen with this? Please allow us to flip the monitor. And also please allow for real timelapse..
    Thanking you in advance,
    Frazier Nivens, Ocean Imaging
    www.oceanimaging.com
    skype: fraziernivens
    EPIC X 1994
    Sep 2011
    Please, sensor reverse scan, not just flip the LCD image. Matching jello artifacts is rather tricky sometimes.
    -Les Dittert
    San Diego, CA
    Monitor flip, more time-lapse capability and pre-roll.
    Give 'em an inch... ,-)
    Cheers - #19
    Sep 2011
    Question for people who want the monitor flip for 3d shoots:
    If you are shooting 3D, are you experiencing much of a problem from one of the cameras exposing the sensor in the opposite direction than the other ?
    So if you pan past a telephone pole, does the top of it tilt away or towards you as the L and R eye 'jello' in opposite directions?
    ( the rolling shutter would change the scan line disparity effectively tilting the image in Z top to bottom )
    Maybe what I'm saying is that just flipping the monitor output is not going to help this situation at all.
    Not a problem shooting static scenes.
    You guys shoot motion, I would assume ;)
    Quote Originally Posted by Frazier Nivens View Post
    -Les Dittert
    Sep 2009
    Ft. Lauderdale, FL
    My rig uses an underslung camera configuration - resulting in a flopped image from the reflection side of the glass (and not a flipped image). In this configuration, both sensors have an identical vertical orientation and scan in the same direction. So - sensor flip is not a requirement for me. Monitor flip and flop IS desperately needed however - as my cameras are both mounted upside down (which is common).
    Senior Member Jason Goodman's Avatar
    Jun 2009
    New York City & Los Angeles
    reversing the scan direction of the sensor is not at all necessary and probably complicated from a software / hardware standpoint. As long as your cameras are oriented such that both sensors are scanning from top to bottom (or bottom to top) relative to the subject, maximum temporal error is reduced to one half of one line time, which is an infinitesimally small duration. If you are using 1/48th shutter and shooting let's say 5K 2:1, 1/2 of one line time is 0.00000407 seconds. I challenge you to find a subject moving fast enough for this temporal error to be noticeable.
    Jason Goodman
    CEO
    21st Century 3D
    http://www.21c3d.com
    jason@21stcentury3d.com
    @21C3D
    Sep 2011
    Thanks Jason,
    I'm actually hoping I can flip one camera upside-down for closer SBS interaxial.
    Also looking into making a couple of 90 degree lens relay mounts to get the lens's touching each other for even closer SBS. Crazy idea?
    I'm not seeing mirror rigs compact enough for 3rd world run and gun 2 person shooting with really wide glass.
    -Les Dittert
    Senior Member Pawel Achtel's Avatar
    Oct 2007
    Tasmania
    Quote Originally Posted by Les Dittert View Post
    Thanks Jason,
    Les, this has been solved...in hardware...
    Pawel Achtel B.Eng(Hons) M.Sc
    www.achtel.com
    Sharp to the Edge
    Land and Underwater Cinematography, Production and Equipment | DeepX - the world's only 5k underwater housing for RED Epic and Scarlet | 3Deep - the ultimate 3D underwater housing - available in US and Europe from Band Pro
    Jun 2009
    one camera upside down in side by side is exactly what you do not want to do. That would make the maximum temporal error one frame time, or 1/48th of a second which is a very noticeable problem. Pawel's solution is far better. 90 degree lens relay might be ok, but I'm not sure if it would work optically.
    Jason Goodman
    CEO
    21st Century 3D
    @21C3D
