I could be the only one, but I find myself in many instances where I just need a single case to protect my SSD, weather on a boat, in the middle of the Everglades, in a car, or even on set when giving the full card to the DIT.
I don't want a neoprene pouch, or something that is big, just something simple and small like the ones for P2 cards.
-Safe from a little splash
-safe from pocket lint
-safe from a small drops
-easy to label and not get confused with the other 3 in the case.
-Clear case so you can see the roll number on the card
-small enough where you can take the foam out of your RED mag case and put 4 cases with cards inside.
How bout it? Anyone else?
