Click here to go to the first RED TEAM post in this thread.   Thread: Help. Can't make multiple subclip
Results 1 to 4 of 4
  1. #1 Help. Can't make multiple subclip
    Senior Member Alvise Tedesco's Avatar
    Milan Italy
    I need to make multiple subclips from single long master clips. Select original clip in browser, add in and out and put that into project. Then I select the original clip again in the browser to give different in and out BUT the "mother" clip in browser appears now short as per in and out added.
    I remember I could do this easily a couple of week ago, don't remember if I was using different Redcine build.
    Macbook 8.3 with Lion and Redcine 13.
    Any suggestion?
  2.   This is the last RED TEAM post in this thread.   #2
    There's a subtlety here -- you'll need to change directories in the browser before selecting the original clip again.
    Otherwise the same clip you just cut is opened again.
    Mar 2011
    Toronto, ON Canada
    Works for me as you described.
    ___________________________
    10 frame handles
    Vimeo
    EPIC-X "SHAI"
    Milan Italy
    ok, thanks.
