Thread: MixPre and Mic-level Inputs on the Epic
Results 1 to 7 of 7
  1. #1 MixPre and Mic-level Inputs on the Epic
    Senior Member Kyle Mallory's Avatar
    Jan 2007
    Salt Lake City
    I'm considering buying a SD MixPre-D and then feeding into the two mic inputs on the camera body, and then I started thinking about how all of this will hook up...
    Since the Epic has no support for Line-Level inputs (infuriating! ), without the Pro-IO module, then that means that the EPIC's pre-amps are going to stomp all over the nice clean signal that is coming from the MixPre. If that is true (and I have no reason to think otherwise), then the only benefit to having the MixPre is... well... mixing, and I might as well save my money on a mixer without high-quality pre-amps.
    Am I correct in this thinking?
    General Tek-Head and Wannabehackfilmmaker Extraordinaire
    IFA Studios and The ReCinema Project
    Dec 2010
    Toronto
    Doesn't the MixPre-D have both line and mic level outputs? I know that it has that "DSLR" output so you don't need to pad the line in order for get a non-overmodulated signal.
    ... that said, yeah, it's kind of bogus if thats the case. Sorry if this sounds presumptuous, but be prepared for "you should be recording to off-board recorder anyway" type responses... par for the course.
    Dec 2009
    Chatsworthless, CA
    You can pad down the line outputs from any mixer, and it'll go into the Epic or Scarlet inputs just fine. The MixPre does have both a line level and mike level output available. My preference for the camera is to attach a Lectro SR wireless receiver instead, which is actually smaller than the MixPre (but weighs about the same with a battery pack). If you drop the Lectro output way down, it won't overload the Epic or Scarlet input.
    www.cinesound.tv | location sound / post-production consultant
    Quote Originally Posted by Marc Wielage View Post
    I have the MixPre, it does not output mike level (only the newer MixPre D outputs line level). The Mixpre and a Hosa ATT-448 attenuator works fine for audio into Scarlet (along with Hosa XVS-101F to adapt XLR to 3.5mm TRS)
    Scotland, UK
    Anyone using the SD 302 with Epic/Scarlet?
    What settings are you using to take audio into the camera using the 302? Is an attenuator required?
    Scott
    Midas Media
    www.midasmedia.tv
    Jun 2008
    Australia
    I am using the SD 744T and I go line level into the Epic attenuated by -25 db and don't really use the preamps on the epic at all. It works really well.
    Robert Castiglione
    www.neweditionsfilm.com
    Dec 2009
    Chatsworthless, CA
    Quote Originally Posted by Werner Jauch View Post
    Correct, they added this feature to the MixPreD, which is the current model. I routinely use the switchable Shure A15S switchable attenuator when I have to feed problematic inputs, especially prosumer cameras.
