Thread: HMI
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 25
  1. #11
    Mar 2012
    ID / WA State
    I have a 1200 w HMI as well as a 2500w HMI. A 1200w HMI will pull 14-15A, so you can plug it to a regular house circuit. my 2500w is a little older and needs a little more power than new ones. It and most (but better check) 2500w will run 90-250v, it pulls 40A at 120v or 20A at 240v. So I can wire it to a 30A dryer outlet. Hot Hot Ground, just be sure to get the ground right. I recently ran a 4k with a newer electronic ballast off a 30A 240v outlet. You could make a 2-15A 120v spicer to a 60A 240v bates but its kindof rinky dinky, I would just use a dryer outlet. Or a 50A Range or welding outlet is even better. Otherwise you will need a 4500w-5500w genny dedicated to the light and with extra gas on hand to run a 2.5k.
    Michael Notar
    WWW.SHUTTERWORKSFILM.COM
    Video Production and Equipment Rentals.
    Jul 2011
    Wisconisn, U.S.A.
    Quote Originally Posted by Trevor Meeks View Post
    Or get a 1.2K and save yourself the hassle :)
    And this isn't really a terrible option. You could just run two 1.2K's off of different circuits.
    Senior Member Trevor Meeks's Avatar
    Jun 2009
    Sonoma, CA
    Quote Originally Posted by Nathaniel Haban View Post
    Exactly!
  4. #14 Just one sugestion...
    Get an Arri M18 with the reflector kit. You can plug it in a 20A house outlet ( dishwasher, etc..)
    It trows light like a mother****er.
    HD HOUSE
    305-597-7359 ------- info@thehdhouse.com
    EPIC-X #211 - EPIC-X #2447 - SCARLET #108 -SCARLET #129 - SCARLET #165 - SCARLET #184 - ARRI ALEXA
    RED PRO PRIMES 18mm, 24mm, 35mm, 50mm, 85mm, 100mm & 300mm
    Arri ULTRAPRIMES 16mm, 20mm, 24mm, 32mm, 50mm, 85mm & 100mm
    RED PRO ZOOM 18-85mm --- RED ZOOM 18-50mm --- RED ZOOM 50-150mm
    Angenieux Optimo DP 16-42mm --- Angenieux Optimo DP 30-80mm --- Tokina "DUCLOS" 11-16mm
    3-Wall CYC Studio - ASM. SCRATCH
    Member Ale Houston's Avatar
    Jun 2011
    Asuncion, Paraguay
    We own two M18 and one M40 and in over 20 years we've been doing this, we've never seen an HMI as versatile as this.. super fast ignition and a really great practical and lightweight ballast... and Arri is really serious when they describe the product as the equivalent of at least a 3.2Kw Arrimax.. and the best part.. plug it on any house outlet without any fancy electrical work.. (but still, do hire an electrician, for your safety and because it wll save you a great amount of time, even in a small to midsize production..
    Quote Originally Posted by Gaston Fazio View Post
    Jun 2011
    Asuncion, Paraguay
    Quote Originally Posted by Peter Berger View Post
    When the Arrimax 1800 first came out there was a lot of discussion on these boards (http://reduser.net/forum/showthread....ource-Question) regarding whether the Arri M18 can operate off a standard wall outlet. With an Apparent Power of 2250VA, it will draw 19.5 amps at 115V and will always trip the common 15amp house circuit and will trip a 20 Amp circuit if there is something else, like a computer or light, on the same circuit. Where you can't always know what else is on the same circuit, or even if it is a 20 or 15 Amp circuit, it is risky to plug the Baby Max into the wall.
    According to the previous thread the M18 was really designed for 230V markets like the European Union where its’ Apparent Power of 2250KVA fits comfortably in a 230V/16A circuit. In 120V markets like the US, to operate the M18 on wall outlets requires a number of precautions according to the previous thread.
    Peter Berger
    We live in a 220V country and so far had no troubles with the M18.. though I still recommend to always have an electrician/gaffer at hand.. not really a good idea to go blind folded to manage lights.. trust the pros...
    Nov 2008
    London
    In the UK we can run 2.5 Arri or Filmgear HMI's off a 13amp 240v household circuit. The rental houses supply 13amp jumpers to allow you to plug into a normal 13A wall socket. I am quite happy running three in a house. We identify the separate circuits. So usually one off the kitchen, one off the ring main downstairs and one off the ring main upstairs. Most UK households have between 60 and 100A feeds so it's absolutely fine running three. Though not sure how this pans out in the States!
    Senior Member Jon Chema's Avatar
    Aug 2009
    Nashville, TN
    Quote Originally Posted by Gregory Sheffer View Post
    I am interested in a 2.5 HMI. My problem is power. Can the plug on a 2.5 hmi be replaced with a standard edison? What are other options for using a big hmi like this without having to have a generator?
    Thanks.
    If you have a Bates to Edison adapter you could power it but it would be pushing the circuit as its right at the threshold of tripping the breaker. I would opt to go with an Arri M18 or buy a Honda 6500w Generator with 30amp bates circuit to be safe.
    Sep 2009
    There's a guy called guy holt.... I think , thatsnhis name .. forgive me guy holt .. if im mistaken ...back east , I think that is the master of what your asking , he rigs small Gennys and step down transformers. S you can plug a 30 amp 220v dryer plug ,and step transform it down to 50 amps of 110 , enough to safely strike and run your 2.5 k Hmi
    Senior Member Michael Panfeld's Avatar
    Nov 2007
    Washington DC
    I'll second that. Guy's company is called ScreenLight & Grip. I have their step-down transformer and a Honda EU6500. The stepdown is great for inside work or shots tht are within a 100-200 feet of a dryer/stove plug. Their 60A stepdown is heavy, about 150 lbs, so buying it also involves a substantial shipping cost. You also will probably want some distro cable and a few pigtails with some of the common 240v plug types. There may be one for rent in your area. (Mine are and I am in the DC area). THe transformer also pairs nicely with the EU6500, for when you are shooting out in the field.
    I beieve they are now making a 100A stepdown transformer. That can plug into either a 50A 240v stove plug or into the Honda 10K genny.
    Note that, while the stepdowns from Guy are basically foolproof, you should still hire a gaffer and definitely don't try to use one anywhere near water.
    Karma vs Mojo Productions LLC - Karma vs Mojo Rentals LLC
    Canon FD (24,28,35,55,85,100,135,200,24-35,28-50,35-70,55-135)
    Super Baltar (20,25,35,50,75,100,150,225)
    Lomo Standard Speed (18,22,28,35,50,75,100,150,200,250,300)
    Lomo Super Speed (18,22,28,35,50,75)
    Lomo Anamorphic (35,50,75,150, 40-240 zoom)
    Lomo Zooms (20-120, 28-80)
    Angie Zooms (20-120, 25-250 "old school")
