Click here to go to the first RED TEAM post in this thread.   Thread: CMOS sensor
Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 49
  1.   This is the last RED TEAM post in this thread.   #31
    Paul, that sounds a reasonable starting point. Always let the image be your guide though - if it looks good it is good, but those recommendations are my starting point.
    Graeme
    www.red.com - 5k Digital Cinema Camera
    Science enables stories. Stories drive science
    FLUT™, Image Processing, Colour Science and Demosaic Algorithms, REDRAY 4K delivery
    Jul 2009
    Thanks Graeme.
    Aug 2008
    Quote Originally Posted by Graeme Nattress View Post
    Not necessarily - just a "beware".
    How it works is that we calibrate the colorimetry of the cameras under a wide variety of light sources, but as I mention above, we don't have any filters in the chain. We pick the appropriate calibration based on the one bit of info we have - the kelvin of the wb, which gives us the indication of tungsten, daylight, somewhere in the middle or "beyond".
    In the extreme case of shooting tungsten light, but filtered to a ~6500k wb, you'd be using daylight calibration with what is still essentially a tungsten source, and I could well imagine the colours wouldn't be right. In that case you could set the wb back to 2800k or 3200k and then use RGB gain to adjust the wb and then you'd be using the correct calibration. But that's the most extreme circumstance.
    In practical circumstances, you're shooting a warm light and leaving the image looking warm. You may be helping the sensor a bit with some filtering, but keeping the warm look. In that case I don't see an issue either way. Say you put some filtering on a tungsten light and cool it a bit, and wb neutral. You may still be absolutely fine as long as you're not changing the effected correlated colour temp by 1000's of kelvin.
    Graeme
    I have experienced some funky red/blue color balance issues using blue filtered GE reveal light bulbs for practicals with my video camera. Canon's white balance and magenta/green tint controls don't compensate properly. I'm sure its much easier to compensate with raw adjustments.
    Senior Member Stephen Williams's Avatar
    Europe
    Quote Originally Posted by paulherrin View Post
    so basically, it's going to be best practice to nail the WB in redcine (or when shooting) and adjust other controls to taste from there. rather, than say - warming up your image by adjusting whitebalance. correct?
    It makes no difference, best practice would be to add some blue filtering to either the light or the camera, you don't need the full 2 stops, however the more the better if your shooting a greenscreen & want fairly high compression. (8:1)
    Epic M owner
    Jul 2009
    While I would agree, One could argue that it doesn't matter if you CTB a tungsten light and then effectively alter exposure by +1.5 EV, or just light tungsten +1.5 EV and adjust Kelvin setting to -gain in the red channel. So long as you are not clipping the Red channel in the first instance the net effect is the same; +1.5EV (or approx 7lux) worth of energy in the blue spectrum. Makes sense, no?
    I think I am making a mess of my conversions, but hope the underlying idea is clear.
    Quote Originally Posted by Stephen Williams View Post
    I'm sorry. It just occurred to me that I am rephrasing what Graeme already said, only he said it better.
    Graeme
    Last edited by Scott Crawley; 04-23-2012 at 07:53 PM. Reason: Added quote from The Nattress
    Quote Originally Posted by Scott Crawley View Post
    Ideally you would balance your lights so that the RAW red green and blue histograms all clipped to white 'simultaneously' on a white card. That way you can push the entire image up into the cleanest range of sensitivity without any clipping channels. The problem with just lighting tungsten and pushing the white balance is that the blues in your skintones and grays will start to clip before the rest of the scene so you'll have to give the entire exposure an extra stop of headroom which you could normally move more usable information into.
    Gavin Greenwalt || im.thatoneguy
    im.thatoneguy[at]gmail.com | Straightface Studios | VFX & Animation
    Canon Scarlet-X package available to rent in Seattle, WA
    Jul 2009
    Quote Originally Posted by Gavin Greenwalt View Post
    The problem with just lighting tungsten and pushing the white balance is that... you'll have to give the entire exposure an extra stop of headroom which you could normally move more usable information into.
    But isn't that exactly what you do when you rate the camera at 800 ISO? I don't see a problem with that.
    I don't suppose that it makes any difference if you invoke -red gain via Kelvin and -green via tint adjustments as opposed to pulling them down anywhere else in the look panel. Graeme, is it the same operation?
    Jan 2008
    Wow, a thread with people that actually talk sense and understand things around here ;)
    Reputation is something the unwise apply.
    But integrity is what the wise apply.
    Graeme
    Surely putting various strengths of CTB gel on tungsten lamps is reducing the level of the tungsten source green and red closer to the level of the blue. Ie REALLY making it more daylight balanced - it's not a "bodge". It's effectively NOT still a tungsten source then.
    OK, CTB gel light transmission curves are not completely smooth, so the transmitted light will not be a perfect "natural" black body daylight spectrum, although it's certainly good enough for film.
    So filtering with full CTB, makes the light source 5600K (or as close as CTB gel manufacturers can make it), and I would expect putting the camera colour temp to 5600K should look right, as it usually does when I've used it.
    Or are you just saying that pushing tungsten towards even more extreme blue ~6500K, the camera is expecting a certain smooth colour spectrum for white, and the actual spectrum due to gel imperfections at that correction strength may well be too distorted and "peaky", so it'd be better to adjust RGB gain in the camera settings while lighting with an ungelled tungsten source, at least as far as colorimetry goes, if not noise performance.
    Of course, it'd be better to start with a daylight source and only modify that a little if we want WB at 6500K, rather than a tungsten source modified a lot. Not to mention the extreme light level loss!
    Director/Digital Camera Operator/2nd AC/DIT/Data Manager
    London, UK.
    Life moves pretty fast. If you don't stop and look around once in a while, you could miss it.
    Jul 2009
    Graeme, if I understood you correctly you were saying that the MX sensor and RAW 16 bit could handle digital gain to the tune of a couple thousand degrees kelvin without any apparent loss of fidelity, and therefore you do not advocate analogue gain over digital gain. Is that correct?
    So are you saying that analogue gain is not inherently better than digital with the MX, or simply that within reasonable ranges of manipulation that there is no appreciable difference between them? ... Because the system is robust enough for that?
    Sorry again if it seems I am just re-phrasing all of your remarks. I'm just trying to get my head around this.
