Click here to go to the first RED TEAM post in this thread.   Thread: Piece Of Advise
Page 1 of 4 1234 LastLast
Results 1 to 10 of 33
  1. #1 Piece Of Advise
    Banned
    Mar 2007
    Athens Greece
    Hi,
    Since time is coming...:innocent: . I would like to make my reservation for all the rest of the accessories. I am thinking of ordering the follow items:
    Base Production Pack
    Red 18-50 mm
    Red 50-150 mm
    Red EVF
    Red LCD
    EVF Cable
    LCD Cable
    2 Red Power Packs
    Red Drive Raid
    Red Flash Drive
    Red Flash CF Module
    3 Compact Flash 8GB
    Red Handle (left)
    Top Handle Exte.
    2 Side Handles
    2 Universal Mounts
    2 Steel 12''
    2 Steel 24''
    2 Bolt Sets
    Focus Hood Set
    AC Power Adapter
    Please advise me in case I forgote something (important item ) or I over order. Thanking you in anticipation.
    Nic
    Hi,
    Knowing that 3 Rolls of 35mm won't make a shooting day I suspect that 3 CF cards won't do it as well.
    Uploading, reformatting in the field is possible but takes time. Backing up data is nothing for a rush.
    IMHO, get at least 8 CF cards.
    Hans
    EDIT: Saw that you ordered a REDRaid. Well, I don't consider harddisks realiable enough for real life production. Might be wrong though.
    Senior Member Marc Berger's Avatar
    Dec 2007
    France
    Do you need an extra EVF cable and LCD cable? They are already included with the EVF and LCD.
    I would take minimum 3 universal mounts.
    Cheers
    Marc
    REDuser Sponsor Jay A. Kelley's Avatar
    Feb 2007
    St. Louis MO
    Quote Originally Posted by spectral View Post
    Hi,
    Red 18-50 mm
    Red 50-150 mm
    Red EVF
    Red LCD
    EVF Cable
    LCD Cable
    2 Red Power Packs
    Red Drive Raid
    Red Flash Drive
    Red Flash CF Module
    3 Compact Flash 8GB
    Red Handle (left)
    Top Handle Exte.
    2 Side Handles
    2 Universal Mounts
    2 Steel 12''
    2 Steel 24''
    2 Bolt Sets
    Focus Hood Set
    AC Power Adapter
    Nic
    How about adaptors for those mini plugs. Do you have those?
    Jay
    Jay A Kelley
    Lead Instructor, Infotech Academy
    RED102. THE BEST ONLINE COURSE FOR SCARLET and EPIC
    http://www.red102.com
    Banned
    Jan 2007
    Hi,
    Red 18-50 mm
    Red 50-150 mm
    Red EVF
    Red LCD
    EVF Cable
    LCD Cable
    2 Red Power Packs
    Red Drive Raid
    Red Flash Drive
    Red Flash CF Module
    3 Compact Flash 8GB
    Red Handle (left)
    Top Handle Exte.
    2 Side Handles
    2 Universal Mounts
    2 Steel 12''
    2 Steel 24''
    2 Bolt Sets
    Focus Hood Set
    AC Power Adapter
    Nic
    In regards to your power packs...I would just get one and order another battery or two. As long as you have your batteries charged before you go on a gig and keep a good rotation as they go down that should be sufficient.
    I also agree that you will need a few more CF cards...remember you should keep a previous build or two (that you can store on CF's) if your current version crashes or what not, and you will also need more "camera rolls". It will hold about 4 1/2 minutes at 4K and will need to be downloaded. You want to make sure you can still shoot while all of this is going on.
    Also, unless you are doing all studio work I would stay away from the raid drive (at least for now) until it's track record gets established.
    The LCD and EVF will come with cables already and unless you want a back up cable (which is a good idea) you don't need to spend this money right off the bat.
    I have my own opinion about the RED handles. I've worked with them and don't think they are that great...they come loose a lot and require constant tightening. I also have my own opinion about not using handles for hand held. I prefer to hold onto the matte box but I won't get into that for now...some people get really upset by this.
    IMHO, I also don't think you really need the handle ext, or the side handles except for vanity reasons. You can get away with just the top handle. Especially if you are going to be switching a lot between hand held or steadicam mode to studio mode. There are a lot of bolts to take off. If time is an issue please consider.
    Regards
    Senior Member I Bloom's Avatar
    Jan 2007
    Manhattan
    Quote Originally Posted by red1225 View Post
    Apparently previous builds can go on an SD card which can be around 256MB is really cheap and fits in a little slot near the front. The good news is... the builds have gotten very stable, so I think swapping builds will be a rarity these days.
    IBloom
    Banned
    Jan 2007
    Quote Originally Posted by ibloom View Post
    IBloom
    Thats why I'm very glad you're close by IBloom!!!:)
    Sep 2007
    good old Berlin
    man, sometimes i am looking through his posts...this guy is great,
    my Top 5 redusers are:
    ian, anders, mark, lucas, chuck colburn.
    man i forgot ketch, david farland, finner, shawn, gibby, gunleik, etc...
    Kaya
    All Ahead Film
    drop me a mail if i can help.
    kaya-at-allahead.de
    Nov 2007
    Quote Originally Posted by marcb View Post
    Marc
    Nothing wrong with having back up cables. Highly recommended. Nothing worse than having a $200.00 cable go down, causing production to shut down for a day or two while you have a replacement shipped out. :waaa:
    You may want to confirm with RED if the EVF and LCD cables may be wired the same, if so, only get a spare LCD if it can be used on both devices, and spend the money on a back up drive cable.
    "The RED-LCD and RED-EVF cables are interchangeable..."
    build_13_ops_guide_v1.8.8.pdf p.4
