Thread: Basic shogun mic kit - will this suffice?
Page 1 of 2 12 LastLast
Results 1 to 10 of 19
  1. #1 Basic shogun mic kit - will this suffice?
    Senior Member Mark K.'s Avatar
    Hi guys,
    Being half-deaf audio has never exactly been one of my strong points, but as I'm in the process of putting together my own production kit for the first time (camera, lights, support and audio) I need to organise the sound recording side of things.
    For starters I figured a basic shotgun/boom kit would suffice (I'll probably add a lav and wireless lav down the track), but I wanted to run this kit past you guys and check whether it's got everything I'll need (and whether it'll suffice for interviews, commercials and corporate videos).
    My plan was to record directly into a Sound Devices PIX240. Will the controls/inputs on that suffice? Or is a separate mixer/pre-amp necessary?
    Any thoughts, opinions or suggestions would be much appreciated.
    buy more expensive cables.. these are not as well RF shielded as Remote audio ones..
    The PSC mic mount or audio technica one are more durable than this rode one.. but they dont have a built in coild shoe fitting.. so... just take care of this mount.. (remove it from the pole and store it in padding when not using it and you'll be ok)
    I like the Rode NTg1, 2, and 3 mics..
    if you are using an EPIC or Scarlet, this mic will be ready to go with an AA battery.. the NTG 1 is lighter, but needs phantom power
    the NTG3 is MUCH nicer... but needs phantom power..
    I think the NT2 sounds better than the Sennheiser ME66/k6 system... and is much less pricy.
    you'll need a longer boom for drama production.. 12 feet minimum. this is a good brand.
    Senior Member David W. Jones's Avatar
    Dec 2007
    La Petite Roche
    I would add a blimp for exterior work, and a hyper mic with BBG for interior work.
    David W. Jones
    www.joneshdfilms.com
    Junior Member
    Feb 2011
    The only problem that I see with this kit; A doc club that I belonged to at MSU bought an internally cabled boom pole, they are great unless you have to move with it. Tried to use the same boom pole on the set of a feature film, and when you have to walk with the boom pole in hand the cable can bang against the inside of the pole. So I learned that internally cabled poles are good in some cases but not all.
    Mark
    Senior Member Mike Tiffee's Avatar
    Nov 2011
    Quote Originally Posted by Christopher Mills View Post
    Actually, buy cheaper cables... but higher quality.
    http://www.monoprice.com/products/su...=10244#1024401
    Freelance Broadcast Technical Director
    Based in Charleston, SC
    Scarlet-X #1456
    Then you bought a cheap one.. or did not know how to move with it.. nicer ones make less noise, sometimes through insulation, better internal cables, jumpers from female xlr (tip of boom end) to the mic with thin cable..
    or both.
    Though, I do know some very experienced boom ops who prefer to use an externally cabled boom rig.
    Part of the point of using the boom is to know how to not conduct noise from your handling of it back to the mic.
    I have both straight and coiled cabled booms, and find the time I save not having to adjust an externally wrapped cable is essential to production..
    Those cables look better than pearstone.. but the Remote audio ones are even nicer
    Well I picked up my basic kit this afternoon. I actually managed to find it cheaper here in Australia than I could get it from B&H (even before including shipping!). I went for the Rode NTG-3 shotgun, with the Rode Blimp, windjammer, 10' boom and a Hosa XLR cable (it all came together in a kit).
    Initial tests with the PIX240 I also picked up today seem really promising.
    Thanks again for the advice and suggestions guys. At this stage, I think a wireless mic will be next, followed by a hypercardioid condenser mic (though I doubt I'll be affording either of those for a while).
    I presume you are using the phantom power from the Pix?
    Should sound very good indeed...
    I like the NTg3 very much... find it is similar quality to Sennheiser 416 (slight pattern difference, and slightly more susceptible to RF hits from smart phones)...
    you can fix the RF issue by replacing the XLR at tip of boom pole with an aftermarket Neutrik RF shielded one..
    When you shop for Hypercardioid.. on a budget... Oktava , AT 5053, and , perhaps Rode (since you can probably test one locally)....
    If you think about buying the last hyper you will exer need... they Schoeps CMC5 or CMC6 ith MK41 head.. (NOT MK41s)
    I also have used an AKG C460 with cardioid and hypercardioid heads and they sound GREAT.. but are available in small quantities,,,
    sort of in between price..
    Senior Member Jeffrey T. Morgan's Avatar
    Oct 2007
    Michigan
    FWIW
    The NTG2 is pretty amazing. Used it for years, just had it take a dive (from massive abuse) and I am using a ME66/K6 from Sennheiser that I had, but I preferred the sound from the NTG2 at half the price. The NTG3 is my favorite shotgun mic, even over the MKH60, etc. The 60 is a close second though.
    I JUST picked up a Rode NT3 for interior work and am LOVING it. Its a bit heavy, but it sounds great, is durable, and is $250 vs the MKH50 at around $1500.
    My next purchase will be a NTG3 and a Sound Devices MixPreD.
    Jeffrey T. Morgan
    Producer • Director • Cinematographer (Local 600) • Editor
    www.PrometheusMotionPictures.com . . . Twitter: (at) JeffreyTMorgan
    SCARLET-X #1633 "The Dark Knight", Now booking Michigan and Worldwide
    Canon and PL Mount, 5" Touch LCD, RedRock FF and Mattebox, Cartoni Delta Head, Contax Zeiss lenses and much more
    Senior Member Jeff Whitehurst's Avatar
    Nov 2011
    Hawaii and all over the Western US
    Just added this Pearstone suspender to my Rode SM3 mount. Much better than the weak bands that come with the SM3.
    http://www.bhphotovideo.com/c/produc...icrophone.html
    Jeff Whitehurst Scarlet-X #1177 "Pearl"
    www.jeffwhitehurst.com
    www.kipukafilms.com
    Nothing Happens Until Something Moves
    - Albert Einstein
