Thread: Speedgrade Raw & DPX Workflow CS-6
Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 52
  1. #31
    Senior Member Mike Tiffee's Avatar
    Nov 2011
    Here are a bunch of Speed Grade videos recently uploaded. Good sneak peek.
    http://tv.adobe.com/search/?q=SpeedGrade
    Freelance Broadcast Technical Director
    Based in Charleston, SC
    Scarlet-X #1456
    Mar 2009
    Kolkata, India
    SpeedGrade CS6 lives up to its name. It is fast, really fast. Running on an AMD Radeon HD 7970, it seems impossible to knock it out of real-time, even at 5K (the bottleneck is the CPU decompression). I gave up after adding 13 layers and the GPU usage was only 65%! You would need multiple GTX 580s in Resolve for this kind of performance.
    It has its share of quirks, more on those later.
    Nov 2007
    Quote Originally Posted by Subhadip Sen View Post
    lol
    Senior Member Mohammed El Sharqawy's Avatar
    May 2007
    Cairo, Egypt
    and how does the 580 perform with SG?
    Cinematographer/Editor/VFX/Colorist
    http://vimeo.com/channels/71836
    Senior Member Brandon J.F.'s Avatar
    Sep 2010
    Mike, thanks for posting this.
    Hybrid Vigor
    Learn: Kickstarter Marketing Video TutorialWatch: Film TeaserRead: Official SiteFollow: TwitterLike: Facebook (new page)
    Our Kickstarter campaign was a Staff Pick! We were also Featured on Kickstarter's home page and we won Indiewire's Project of the Week with over 70% of the total votes. Our campaign was very successful. The fundraising continues.
    Scarlet-X #6
    Senior Member paulherrin's Avatar
    Oct 2008
    Johnson City, TN
    Do you have to modify your project to all sit on one video layer in premiere, or is there some way to export an EDL and preserve your editing layers. What about transitions, transforms, etc... will those work in an EDL?
    Finally, when you export the DPX sequences, does it just turn into one long element in Speedgrade, or will they stay cut up? What about transitions and keyframes in that case?
    Scarlet-X #970 "Silver"
    www.yah-sav.com
    Mar 2009
    Kolkata, India
    Tried out GTX 580. There's some image corruption with the latest 301.xx drivers, had to roll back to 296.xx with which everything works fine. Performance is down from 7970 but still pretty good. The timeline that was playing real-time at 1/2 res (2560x1280) is now dropping back to 1/4 (1280x640). GPU usage is around ~90%. With a more realistic array of layers, GTX 580 handles things pretty easily at 1/2 res for 5K files. Also, I noticed 12 GB RAM usage, which seems to indicate that SG caches rendered frames aggressively. I will test it thoroughly next weekend, these are just preliminary observations and it is quite possible I am missing something.
    By the way, give it a try - follow Kemalettin's instructions here: http://reduser.net/forum/showthread....l=1#post997542. Would love to hear how it's working for you guys.
    Norway
    Quote Originally Posted by David McGavran View Post
    As you note Speedgrade is very new to the Adobe family. We did what we could in this release to have some integration. It won't be perfect for everyone. We are going to be looking for feedback as we work on much deeper integration in the future. For the time being. The Send to Speedgrade feature exports your sequence as a series of DPX sequences that you can grade. Premiere also exports EDL and Speedgrade imports EDL. Speedgrade has native support for R3D's and lots of other popular formats and their relinking is great.
    Cheers
    Dave
    grading from DPX's baked with editing metadata is probably not a very good startingpoint, and also a bit of a strange choice, considering one of speedgrades strongpoints is its (RED and other cameras), RAW integration...
    G
    Life is good. So is RED...
    http://youtu.be/mhFB1CMzQBM
    http://bit.ly/mCwcoN
    Twitter: gunleik
    Member Lin's Avatar
    Jan 2007
    Munich, Germany
    Hi Subhadip,
    you can control the amount of RAM being used for the cache in the SpeedGrade user settings: Hit 'S' to switch to the settings tab, then click on 'Cache'. The default is 50% of your RAM, which is usually a value you don't have to change unless you are using Premiere/After Effects or another RAM-heavy application in parallel.
    Lin
    Lin Sebastian Kayser | Adobe Pro Video Group Engineering Director | Founder of IRIDAS
    Member Lin's Avatar
    Jan 2007
    Munich, Germany
    Quote Originally Posted by Gunleik Groven View Post
    G
    Gunleik - the DPX route is meant as an 'will always work' fallback method. For RED users the EDL route is very straightforward and much more elegant. While SpeedGrade, because of where it comes from, supports basically all of the 'Digital Film' file formats, it does not yet support the vast amount of formats that comes from come from cameras mainly used in the broadcast industry. For those formats, 'Send to SpeedGrade' is the right tool for now.
    Lin
Tags for this Thread
View Tag Cloud
