Thread: MOTION CONTROL W/ EPIC? ISSUES? FRAMERATES OVER 24-30FPS???
Results 1 to 8 of 8
  1. #1 MOTION CONTROL W/ EPIC? ISSUES? FRAMERATES OVER 24-30FPS???
    Oct 2009
    Washington DC / DC METRO
    Has anyone done any MOCO (MILO, FALCON) work with EPIC?
    Any specific issues?
    Anyone used high frame rates.
    Got a job coming up and I'm looking to avoid any traps.
    Senior Member Stephen Williams's Avatar
    Europe
    Quote Originally Posted by A.Fetchko View Post
    Are you doing multi passes? if so it's possible to fire the Epic with frame sync at half the max frame rete. This was never possible with R1-
    Epic Dragon owner, the first upgraded camera in Switzerland :D
    Dec 2009
    Montreal
    Here a great trick: Fire you cam before the beginning of your move (so record your move playback to start as still/nothing for at least ten seconds), but always fire in synch with the same spot (i.e., still at exactly the same time as firing the beginning of the move). That way if motion move playback is slow to start, or cam is slow to get into Rec mode, for whatever reason, you still get your take, and the worst it could be off is 1/48th of a second, which may not even show depending on how things are layered. You never know when the best take might happen...
  5. #5
    Bloop Light!
    Michael Hardwick
    Cinematographer
    Digital Image Technician
    IATSE Local 600
    Oct 2009
    I've done several MOCO shoots with my RED ONE and no problem really.
    But I've heard that the EPIC does NOT sync properly and that this caused magor problems on the HOBBIT.
    We've always just genlocked the REDONE and the RIG to tri-level but this time client wants to shoot at 72 or 96 FPS
    Europe
    Quote Originally Posted by Rob Ruffo View Post
    1/48 error will ruin many multi pass shots, just like with 3D sync is vital. It depends hugely on the type of move / Speed / quality of end result.
    If you do it the way I say every take is exactly the same length, just like 35mm!
    If you have shutter sync you can shoot at different frame rates & speed ramp in camera, all takes will fit .......
    Europe
    Quote Originally Posted by Michael Hardwick View Post
    Bloop Light!
    A bloop light will only show you a sync frame, it makes no account of the shutter sync, a big issue if frame rates are 3,6,12,24,48 & 96 fps of the same move.
