Click here to go to the first RED TEAM post in this thread.   Thread: EPIC stops recording when pointed at bright sky
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 21
  1. #11 Problem replicated
    Member Richard N. Metzker's Avatar
    Apr 2009
    Vancouver, Canada
    Pieter's problem is real. The problem has been replicated with firmware versions 2.0.5...
    Get the Bug Fixer ready...
    Richard
    Quote Originally Posted by pieterstathis View Post
    Hey guys,
    has anyone ever had this happen? i'm shooting with EPIC build 3.0.
    the shot calls for a transition tilting down from the sky onto the actors.
    my camera starts pointed level to shoot the slate, then i tilt up to a bright overcast sky and then tilt down to transition into the scene.
    the camera's red roll button and time-code have turned red and keep showing we are rolling, but the SSD percentage counter doesn't count down.
    and when we check playback, the camera has actually stopped recording as soon as the entire frame is covered with overexposed, white sky.
    i tried this a few times with both of our EPIC bodies and identified that the cameras will not roll when the frame is 100% filled with bright, uniformly overexposed white information. i tried a similar bench test with the lens off and the resulting blown out white image and when i roll, the camera hiccups a few frames and then cuts out even though it appears to keep rolling according to the active red roll button and red time-code numbers.
    is this just a firmware or software glitch -- or is it a safety feature to somehow protect the sensor from burning out?
    anyone ever experienced something like this before?
    for the time being, no more shooting the bright sky :)
    thanks,
    Pieter.
    Senior Member Björn Benckert's Avatar
    Dec 2007
    Stockholm, Sweden
    I know it's the wrong thread but we got random one 1 errors on the last couple of jobs. I have not saved out the frames / clips so far (did not have the time).
    But is anyone else experiencing a frame or half a frame of digital noise once in a while?
    a bit scary I think.
    /b
    Björn Benckert
    +46855524900 www.syndicate.se
    Flame - 3D - Epic - HAWK C 35-135mm - Milo MoCo - Droidworx Mikrokopter
    A excellent example how having an open dialogue with your customers can accelerate product development and thus prevent consequential losses to end user.
    In this case only a few days for the bug to be fixed!
    Do all Red owners receive an email regarding the problem and fix?
    It also serves as a reminder that high tech kit can produce some bizarre bugs and that there is only so much testing of major software updates can be done in the factory.
    Mike Brennan
    Dec 2008
    Could this be a bug for Scarlet also?
  5.   Click here to go to the next RED TEAM post in this thread.
  #15
    We've rolled out FW build 3.0.6 which includes an update that should address this problem
    -- Matthew Biederman
    Dec 2011
    Vancouver, BC
    Shot bright sky with my Scarlet-no problem.
    Scarlet#772
    Junior Member
    Apr 2012
    South Australia
    I tested mine and I have same problem.
    Senior Member Matt Ryan's Avatar
    May 2008
    Long Beach, CA.
    Quote Originally Posted by Hussain Neissi View Post
    update to the newest firmware for the fix...
    planetearth
    I had a similar issue. Was shooting in a very white desert, with extremely bright light in Africa. After swapping out a lens I suddenly I couldn't record and there was no image on the screen. Did a black shading and all was fine after that. Freaked me out though. I thought my camera was down and I was in the middle of nowhere with no backup.
  10.   This is the last RED TEAM post in this thread.   #20
    Red Team Stuart English's Avatar
    Irvine, Ca
    Quote Originally Posted by TheBied View Post
    To restate what Matt said earlier in this thread. Please try that if you see this issue.
    If that does NOT resolve your issue, please contact us and send us a camera LOG file....
    Workflow Wizard
