Click here to go to the first RED TEAM post in this thread.   Thread: Send good audio to RED EPIC
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. #1 Send good audio to RED EPIC
    Hi everybody, I have a question for you. I´m a sound recordist and I have to work with the RED EPIC.
    I had worked two days with this camera and I send mic level audio by the 3.5 mm audio jacks from my Sound Devices 302.
    Do you have a best choice to send audio to the EPIC? Also I have a SD 744T and I´m using it as a back up recorder.
    Could you send line level signal by the 3.5 mm jacks?
    I will really appreciate your answer, thank you and best wishes.
    You can send line level signal to the camera if you use an in line attenuator... At least for now. I think your method is spot on, except you may want to think of your 744T as your primary recorder and the audio on the Epic a scratch track or back up. Depends on the project I guess, but the 744T sound is obviously going to be superior to the sound recorded on camera. Good luck!
    Clint Lealos
    Director of Photography
    Yeah, that's a forklift tattoo. I wasn't always a cinematographer :)
    Feb 2011
    Baltimore, MD
    Hey Clint, long time no see. Maybe you know....I got my Scarlet just recently but am unable to get any clean audio in using either a wireless lav of handheld wired mic. All I hear is a humming sound no matter what settings I try. Have you seen this issue?
    Martin Whittier
    Steadicam Operator / Owner
    www.BrumarFilms.com
    Scarlet-X #1365 / Steadicam Archer2
    Oct 2008
    Gorham, Maine
    Quote Originally Posted by Martin Whittier View Post
    sounds like a bad cable: http://reduser.net/forum/showthread....Work-(And-why)
    David Fuller
    AirStream Pictures
    RED ONE #172MX
    EPIC-M #1053
    Senior Member Josh Beadle's Avatar
    Sep 2011
    SoCali
    From what I have read here and my little bit of hands on experience - it seems that the Epic was designed to be a multi-person crew movie camera where the assumption is that there will be a dedicated audio specialist running second system sound. The Epic audio section seems to be that of a 5DII. Coming from an AF100 this took me a bit off guard since everything else about the Epic is top rate.
    I use the Zoom recorder and mix in post - which for simple interview or doc work is a single shooter challenge and workflow pain. That's why my AF100 stills has a solid place in the bag
    Josh
    Epic-M 1388 aka "Black Sheep"
    ATV FamFun
    It's not your camera's fault:
    http://www.youtube.com/watch?v=jJm2EGNIod0&feature=related
    "Your first 10,000 photographs are your worst"
    Henri Cartier-Bresson
    This may be helpful:
    http://vimeo.com/35924296
    Audio was recorded using Sound Devices Mixpre, attenuator and Hosa XLR to 3.5mm cable. (I believe that since then Red sells a better constructed cable).
    Scotland, UK
    What's the general consensus on Epic/Scarlet's onboard audio recording quality? Is it the same as the audio on RED One? Is it unacceptable for broadcast use?
    Our Epic has yet to arrive so we have not had the chance to test the sound quality yet.
    I don't understand why these cameras are facing audio quality scrutiny - audio recording technology is so mature that in this day and age I take it as granted that all "pro" cameras should have full broadcast quality onboard audio capability. Perhaps we need a Sound Devices module for Epic/Scarlet if RED has failed to make the grade in the audio department!
    One of the first lessons I learned is that "poor" footage can often be rescued but bad audio is a MUCH bigger problem to fix!
    Feedback from audio pros appreciated.
    Best wishes
    Scott
    Midas Media
    www.midasmedia.tv
    Jan 2008
    Quote Originally Posted by Scott Brown View Post
    Agree...
    Our 4 year old REDONE has fantastic AUDIO...
    Epic is, well.. Average to say the least...
    If somebody can tell me how to get clean, loud audio onto my flies, (just like the RED ONE) I'd be a very happy man...
    Mark Toia
    www.toia.com
    www.zoomfilmtv.com.au
    Scotland, UK
    Hey Mark
    Thanks for the heads up on Epic's non epic sound quality! This should not be the case when RED One has been useable since the early audio board replacement.
    Best wishes
    SCOTT
    Midas Media
    www.midasmedia.tv
    Dec 2009
    Chatsworthless, CA
    I have yet to encounter one that can, over the past 20 years. Maybe I've been unlucky.
    You will always get better quality sound recording double-system, with a dedicated mixer and audio recorder. I would say that whether you're recording Alexa, Red, Sony, Canon, Panavision, JVC, Ikegami, or anything else. The preamps in all these cameras are just not very good, and there's a great risk of having somebody bump a knob or otherwise change the levels in a detrimental way.
    I have no problem with people shooting under dangerous conditions (wars, riots, street footage, jungles) with onboard microphones, where there are no other options and you're literally running down the street. I also have no problem with it being used for B-roll footage, which is pretty standard, even at network/feature doco levels.
    The other advantage of recording separately is the ability to multitrack. I have had occasions where 10 or 12 tracks was not enough to capture everything on the set, and that's hard to do on one camera. And in all cases, I strongly suggest that one or more of the cameras gets at least a mono reference audio feed to aid in syncing.
    www.cinesound.tv | location sound / post-production consultant
